I get where your coming from and appreciate the info. Ive talked to Jake at motiv and we will do what we can to get the car dialed in as best as we can for track reliability. The only single kit i would get is the motiv and i dont have the funds to spend that much yet but one day will. So for time being even if the pure last me 2 years ill be more than happy with them. I do about 1-2 track days a month. And i dont track during the summer months.
Any links to your build would love to see what been done and what it looks like? Cant see you location but what tracks have you taken your car to? Being in Socal ive only been to the local ones: Big willow, streets of willow, Autoclub speedway and Buttonwillow (my favorite by far)
If your goal is simply 550-600hp. I would still just get the high flows. Stock engine will be happier running less boost for rated HP than running the DD's at a higher pressure ratio to make the power goal. try not to size turbos for a goal that will run them at their limit.
Motiv's kit is real nice for sure, but I do wish they had a twin scroll manifold and fitment for Borg Warner EFR turbos. There are other great single turbo kit out there too just FYI.
I don't really have build thread or anything like that, too lazy to write such thing lol. But I will probably write up something once I get my new setup running after the new year. Still waiting for Anthony from ACF to ship me top mount kit along with the EFR 7670 turbo. I am glad to finally ditch the rattling stock turbos.
If it helps, I do have a wheelwell page for the car (https://wheelwell.com/thomas-y/jnc/2009-bmw-3-series). My goal for this car is to improve both the handling and power without sacrificing too much on comfort.
I am at Chicago, so just the tracks around the midwest region (Gingerman, Road America, Autobahn, etc.)
the high flows will generate less heat throughout a 15-20 session on the track compared to the DD's. Consider this.I get that the hiflows allow for more power and running less boost to reach my goal but my goal is being hit with car running full e85 and stock turbos. I think i should be good till i have the funds to go single with built motor and turn ny 1er into a full blown track animal
After reading everything, and what your plan is, I think you should just grab the High Flows honestly. The "lag" becomes a null point on the track when you're holding proper gears\rpms. So why not keep temps, and make your motor stress less by running the high flows instead of the DD?
Pure's costumer service has always been fantastic from what I've seen, I'm sure they'd have no problem with you wanting to upgrade.Yeah i see what your saying kinda wish i did but little too late since i already ordered them last week.
I doubt it makes a difference. Both are still using the same stock turbine housing (so the same A/R ratio). The only difference is that the wheels are bit larger.the high flows will generate less heat throughout a 15-20 session on the track compared to the DD's. Consider this.
You were right they switched it for me.
Now im wondering how the hiflows will be with low boost? Might be better to have a tad bit of lag coming out of corners so the back end doesnt start dancing around on me
Which equates to less RPM's of the turbo, which equates to less heat being produced.I doubt it makes a difference. Both are still using the same stock turbine housing (so the same A/R ratio). The only difference is that the wheels are bit larger.
