Overkill Garage - DIY Single Turbo GTX3584RS
OverkillGarage
14
23
Broken Arrow, OK
07 BMW 335i
Creating my own single turbo setup. A few suspension parts are being replaced in conjunction as well as new fuel system components.
Feel free to follow here or on FB/IG via username OverkillGarage. Constructive criticism always appreciated and encouraged. šŸ‘
DIY turbo kits FTW! Also how did you get that manifold deck so clean? Mine was pretty good without any real effort but that is clean
Reactions: OverkillGarage
OverkillGarage
14
23
Broken Arrow, OK
07 BMW 335i
Thanks! I think what you are seeing is the head flange mounted to the cyl head. I got it cleaned up, but probably about the same as most. Unfortunately it appears I don't have a picture of the bare head currently for comparison.
OverkillGarage
14
23
Broken Arrow, OK
07 BMW 335i
I’m sure it’s just the picture angles, but do you have enough room for the water inlet to the block?
It's pretty tight back there. I worked on the tube routing a bit last night and I think I've got a plan in place. I'll try to get pictures up as I make progress.
very nice o2 placement and wg... keep it up, when it comes time to make the DP try making it 3.5"
Thanks! I believe you had a manifold similar to this at one point right? I'm planning on running 3" turbo back. The price penalty of 3.5" comparatively seemed disproportionate for a small gain in power output.
Aren’t the O2 sensors likely going to be getting bad readings since the collector isn’t divided and the sensors are angled with the flow stream?
I'll let Omar reply here, but I think they should be fine. I'm planning to use the VTT screw-in adapters to keep the sensors alive.
Reactions: The Convert
