New Half Mile World Record for Stock Auto Trans: 168.1 MPH in a ST 135i
Omar@VaderSolutions
Premium Vendor
Oct 19, 2016
535
409
NY & AZ
vadersolution.com
N54 135i & N54 335i
Hello everyone, i made this announcement earlier in the facebook page already but thought i give a more detailed post here...
so yesterday i set the trap speed record for stock auto trans in half mile at 168.1 , thank you to everyone who helped during the event. I put this car together literally last minute in a 3 week time span, it was not easy and the car finally got dialed in at the track.
Transmission Temps were rock solid staying under 180*F , also IAT did not go over 127*F even in the hot Arizona Weather. Car made 703WHP on dynojet with o2 sensor flying off everytime, the 168.1 MPH pass was with 26PSI
MODS
Stock Sealed N54 Motor and Trans
Jpworkz ST Kit
AGP DBB 666 Turbo (66/66)
JB4 w/ JB4 PI controller
VRSF 7.5 Race Intercooler
VRSF 335D Charge Pipe w/ 3" Lower CP
BimmerLife Tuning BEF
BimmerLife Tuning Coil-packs
XHP Stage 3 Trans Flash
AD-E PI
AD-E Motor Mounts
CSF Radiator (thanks to ad-e)
Vader Solutions Billet Bucketless Fuel System
Vader Solutions High Flow Turbo Inlet
Vader Solutions PCV Delete Breather System
Vader Solutions Trans Cooler
Vader Solutions Trans Mount
Heres a video compilation of the event
Clean WHP
173
136
2010 135i Msport 6MT
Nice results and very impressive! That engine bay is so clean and well put together. Just curious how many miles are on your auto trans? also on your car/motor in general?
Volrath
27
E92 N54
cyl 5 misfire? The good ol mysterious cyl 5... Curious to know about the post above as well..
chrisdfv
270
216
E90 335i
Are you going flash only now? Any particular reason? I've had my JB4 for the longest, but can't decide if I should keep it or not when I go ST.
dyezak
1,768
1,518
Plano TX
335is
This was an automatic 335i on a 6266.
[Broken Image Removed]
Terry@BMS
Jan 23, 2017
462
379
Yes our auto trap record fell this weekend. Interestingly, JB4 saved the day too, as it so often does. During his earlier runs he had a major WMI leak. JB4 stopped it from making boost and after awhile he was able to find meth literally spraying out of this crappy push lock tee. He fixed it by bypassing tee, with only one nozzle, causing a huge 30% bank to bank trim variance... JB4 stopped that run too. Finally he tracked me down in the pits, we fixed the leak properly with a new compression tee so both nozzles were flowing, and whala, new automatic record. :)
2,191
I don't understand why people bother with push lock when spraying something so damn flammable. Nice the JB4 did it's job.
Terry@BMS
Jan 23, 2017
462
379
It's sort of a hodge podge setup but I convinced him to redo the meth kit. I think it was mostly snow parts, with our FSB running it. It's a JP works manifold with a journal bearing turbo, and 5" intercooler. So, budget was definitely a factor. :)
dyezak
1,768
1,518
Plano TX
335is
HAHAHA. I don't know what's funnier, your comment or the beating Tony subjects himself too over on bummer boost trying to explain this fact.
TEC
81
Tony creates his own issues. His are totally self inflicted.
