SOLD 2009 335i e92 6mt single turbo - $15,000 *sold*
Mikejones1208
145
115
Savannah, GA
2009 BMW 335i
up for sale is my 335i with 81k miles on the car, currently located in savannah ga, mod list is as followed
Factory options
-cold weather package
-sport package
-idrive (lci updated version)
-black leather interior in very good condition
-6 speed manual transmission
-logic radio system
Engine
-AC Fabrication Single turbo kit W/ Pt6466
-Stock factory longblock
-Custom external pcv system (VTA on high side, vacuum on low side)
-Vader solutions triple pump bracket w/ dual walbro 450's
-Motiv Motorsports Flex Fuel
-Motiv Motorsports BoostBox
-Motiv Motorsports oil cooler thermostat delete plate
-Motiv Motorsports Twin Disc SST clutch
-PSP oil cooler core & mounting bracket
-Improved Racing 185 degree oil thermostat
-CP-E port injection rail
-VRSF 7.5" race intercooler
-Synapse blow-off valve
-Synapse charge pipe
-n20 spark plugs
-Bimmerlife R8 coil pack retrofit
-ADV o2 sensors
-Aeromotive fuel pressure regulator
-upgraded custom 6an fuel feed line and return line
-OEM index 12 injectors
Exhaust
-AC Fabrication single turbo downpipe
-AFE Power catback
Tuning Solution
-Flash only w/ MHD
-Custom flex fuel tune by Chris Kontos of Motiv Motorsport
Suspension/Driveline
-Fortune Auto 500 series coilover 8k/10k spring rates
-Condor Speed Shop solid UHMW subframe bushings
-Condor Speed Shop poly trans mounts
-Condor Speed Shop solid UHMW differential bushings
-OEM rear M3 sway bar
-OEM DCT M3 lsd
-OEM M3 rear axles
-Whiteline rear trailing arm bushings
-Whiteline inner lateral arm bushings
-Powerflex outer lateral arm bushings
-Godspeed adjustable control arms
Brakes
-Stoptech drilled and slotted rotors front & rear
-Stoptech street pads front
-Stoptech stainless braided brake lines all around
-Hawk street pads rear
-Motul RBF 600 dot 4 racing brake fluid
Shifter
-Condor speedshop tall weighted shift knob
-Garagistic rear poly shifter carrier
-ECS teflon oval shifter bushings
-UUC adjustable short shift kit
Wheels
-Forgestar f14 drag wheels 17x10/17x8
-Toyo R888R 275/40-17 rear tires
-Mickey Thompson countryman 245/45-17 front tires
-spare set of oem wheels with good tires
Recent Maintenance
-oil pan gasket
-oil filter housing gasket
-oil cooler housing gasket
-front main seal
-rear main seal
-vanos seals
-water pump
-valve cover and gasket
-injector seals
cons
-about due for new engine mounts
-front bumper and hood have rock chips
car runs and drives great tuned on 26 psi on e50 no smoke, no burning or leaking oil, no misfires. i built this car myself front to back and have left no stone unturned, feel free to text, call, or pm me with any questions at all at 9123120189 can provide ample pics to potential buyers!!
25348
25349
25350
25351
