Video WORLD RECORD: Manual BMW 135i runs 10.3 @ 134mph!
suspenceful
10 Second Club
Aug 1, 2017
559
591
75
2015 M3, 2008 135i, 2009 335i
I haven't been as active on the forums lately... YouTube and Instagram are where I post most of my content now. If you aren't already subscribed/following there, you're missing out ;)
That being said, I have exciting news I want to share! I took the car to the drag strip after doing a ton of modifications (listed below). My previous best was 10.90 @ 136mph with full interior, stock diff, stock axles and radial tires. I did a bunch of weight reduction, upgraded my diff, axles, suspension and tires and went back to the strip. Results below:
1st pass (20psi): 11.29 @ 128mph with a 1.94 60ft
2nd pass (25psi): 10.53 @ 137mph with a 1.73 60ft
3rd pass (28psi): 10.36 @ 134mph with a 1.59 60ft
The old record for a manual N54/N55 with stock BMW chassis was 10.70 @ 135mph, but I'm now the fastest after beating it by almost half a second! Yes, Ghassan Automotive went 9.6 but they have a custom back-halfed drag chassis. I think I can run 9's as the car was misfiring during my 10.36 pass.
The car has made 752whp and 691wtq at 30psi. Being at ~28psi with a misfire, I'd guess it was making ~700whp on this pass. Log below.
Full modification list here: https://my1series.com/modifications/
Log: https://datazap.me/u/suspenceful/1036-13409mph?log=0&data=1-3-4-11-25-26-27-28-29
Watch the video!
PERFORMANCE
- Doc Race 6266 single turbo kit: https://bit.ly/302yZjz
- Doc Race intake manifold & PI kit: https://bit.ly/2PO3CEI
- Doc Race 3" charge pipe: https://bit.ly/2VjciZQ
- TiAL Q blow off valve: https://amzn.to/2HdILpt
- VRSF 7.5" Race intercooler: https://bit.ly/2vLjvm8
- PR ignition kit: https://bit.ly/2KcIM02
- PR Stage 3 fuel pump: https://bit.ly/2XFAXI1
- PR upgraded fuel feed line: https://bit.ly/3elYSlP
- NGK 97506 spark plugs @ 0.022": https://bit.ly/2TvoDVQ
DRIVETRAIN
- MFactory 3.08 LSD: https://bit.ly/2ZqtxK9
- DSS 1000HP axles: https://bit.ly/2Zv5be7
- BMS differential brace: https://bit.ly/329Kara
- Powerflex differential bushings: https://bit.ly/3coGOFG & https://bit.ly/2RJ5aC8
- Redline 75W90 differential fluid (2 qts): https://amzn.to/2J6pPt7
SUSPENSION
- Eibach Pro-Kit lowering springs: https://bit.ly/2HFyfqm
- Competition Engineering adjustable drag shocks: https://ebay.to/2GYm3Tu
- M3/1M front & rear control arm kit: https://bit.ly/2yomLbC
- BimmerWorld M3/1M front control arm bearing upgrade: https://bit.ly/2NM5A9Z
- BimmerWorld solid rear subframe mounts: https://bit.ly/2Hr9TmL
- BimmerWorld adjustable rear toe arms: https://bit.ly/30L18fi
- BimmerWorld rear camber arm bearing kit: https://bit.ly/325UbFJ
- ECS Tuning performance rear trailing arms: https://bit.ly/30B5PYO
- BimmerWorld rear trailing arm bearings: https://bit.ly/2L057z3
TUNING
- JB4 tuner: https://bit.ly/2t8Hevi
- JB4 Bluetooth connect kit: https://bit.ly/2DXGOOH
- JB4 port injection controller: https://bit.ly/3eurBEO
- Free JB4+MHD flashes: https://bit.ly/2V79udi
- MHD flashing cable: https://amzn.to/3cqNpPQ
- OTG USB adapter: https://amzn.to/2qKvc9R
TRANSMISSION (MANUAL)
- XClutch ceramic twin disc clutch: https://bit.ly/2VwCoWI
- RTD chassis-mounted shifter: https://bit.ly/2vIKzm3
- Poly transmission mounts: https://bit.ly/3bgkKNs
- Upgraded clutch delay valve: https://bit.ly/2LudXYd
- BMS clutch pedal stop: https://bit.ly/3eoeBRr
- Royal Purple trans fluid (2 qts): https://amzn.to/2VqSLqF
WHEELS/TIRES/BRAKES
- Racestar 92 Drag Star front (17x4.5"): https://ebay.to/37mCeGI
- Racestar 92 Drag Star rear (15x10"): https://ebay.to/3dV4BhM
- MT ET Fronts 26x4x17" tires: https://ebay.to/3hmqQiA
- MT ET Drag 26x10x15 tires: https://ebay.to/2XRMrI4
- Rear calipers for 15" wheels: https://bit.ly/2LaHD9g & https://bit.ly/2Zg24eG
- Rear rotors and pads: https://ebay.to/2GTkPt1
- 3 series rear hub (x2) (E82 only): https://bit.ly/2MGxLqP
- Rear wheel bearing kit (x2) (E82 only): https://bit.ly/341a41W
- Hubcentric rings for Racestar wheels: https://ebay.to/36X8azC
- Wheel stud conversion kit: https://bit.ly/2zPJ7mW
EXTERIOR
- 1M-style front bumper: https://bit.ly/2z6nzT6
- Seibon M3-style carbon fiber hood: https://bit.ly/2VMCedZ
- Seibon CSL-style carbon fiber trunk: https://bit.ly/2z7c1ir
- Rieger rear diffuser: https://ebay.to/2RGQiEz
- BMW Blackline taillights: https://bit.ly/2y1dhCO
- Sideskirt splitters: https://bit.ly/2vGdAyW
- Smoked LED side markers: https://amzn.to/2Lw5h3l
- LUX H8 180 LED angel eyes: https://amzn.to/3ckTPAf
- Gloss black front grilles: https://bit.ly/2VlvRk9
- Black BMW roundel overlay kit: https://bit.ly/2sZHpsv
- BMW ///M license plate frame: https://bit.ly/3cstK1Z
- LED license plate lights: https://amzn.to/2Hainkd
INTERIOR
- Corbeau FX1 Pro seats: https://bit.ly/2VdAP0R
- VAC Motorsports roll bar: https://bit.ly/2XI7flx
- NRW carbon fiber/alcantara steering wheel: https://bit.ly/2yYmGf9
- NRW carbon fiber sunroof delete: https://bit.ly/3cpFEde
- Project Carbon door cards: https://bit.ly/34L8lyv
- BMW Performance shift boot: https://bit.ly/2J5idLJ
- LED interior kit: https://bit.ly/2JsL79c
- Deka 17lb battery: https://amzn.to/2HtYYJ3
- Macht Schnell battery enclosure: https://bit.ly/2ygNkQi
ACCESSORIES
- BMS PCV: https://bit.ly/34HjnVv
- BMS oil catch can: https://bit.ly/2HTxsaJ
- Billet oil filter cap: https://bit.ly/2nDj1KW
- 3.5 bar TMAP sensor: https://bit.ly/3ckVJAT
- 3.5 bar adapter harness: https://bit.ly/34EM2dM
- BMS cowl filters: https://bit.ly/2l4082g
1,929
664
Watch the video!
PERFORMANCE
DRIVETRAIN
SUSPENSION
TUNING
WHEELS/TIRES/BRAKES
EXTERIOR
INTERIOR
ACCESSORIES
Nice shifting bro sounds like an air shifter lol
Reactions: suspenceful
Boostedbmw89
9
2009 135i
Interested on the install of these drag shocks. Seen a couple threads of some things needing altered to fit these. Any more details on this. Beautiful setup btw.
Brule
367
432
335i 2007 6spd manual
lol
Its just not a record.
The others modify there cars to go fast.
Then some muppets say they have a record becsuse they dont have good parts to go fast.
No record to get other then beating 9.34.
Reactions: RuskiRacer
derekgates
740
370
NW FL
derekgates.us
2011 335is
Congrats on the time @suspenceful !
I've enjoyed watching you build the car up. I am a little disappointed that you are on IG more than forums as we are eroding away the internet by putting more and more content in the realm of walled gardens. I won't be following you on IG due to Facebook (and my lack of account) but I wish you luck with the endeavor.
Loving the interior changes with the car. Do you daily the 1 series at all anymore with the F80 in the stable?
Reactions: b4llistic
