Another 500whp Stock Turbo N54
Nov 5, 2016
19
15
Lake Worth, FL
It seems like 500whp is a normal occurrence for stock turbo N54's these days. While I consider these type of results beyond the safe limits of hardware, it is always fun to push things. This customer came to us and said he wanted 500whp, so that's what he got.
A few notes on the car/setup:
-Boost Addictions custom backend flash
-JB4
-Port injection w/e85
-TFT Inlets
-MMP Outlets
-Downpipes
-Intercooler
-4th gear pull
-93*+ ambient temp
-6at No alpina flash. As you can see by the tq curve the trans wasn't happy at all. On one run it just completely let go.
-Stock Knock sensor settings
4,350
Very nice, what stage pump(I presume your brand) and how many miles on the trans?
Nov 5, 2016
19
15
Lake Worth, FL
This car has the fuel-it pi and stage 3 pumps. Idk about the trans mileage, but I think it was pretty low. He had swapped a new one in and did a fluid flush the week before the tune. With a cooler I think it would have been fine. Anything over 180* and the trans wasn't happy. If you can keep a transmission between 140-170* they will live a long time.
Snelson3003
325
199
Denver
www.nelsonracingwheel.com
2010 BMW 135i
That is ALOT of timing. Whew! But timing is stable which is amazing - gotta love PI.
My friend locally maxed his turbos the same way, PWM at 99 and FF at 150, he still has ZERO issue with his turbos. Not a leak or an ounce of oil being burned.
So who knows, with PI maybe it keeps AFR's nice and solid which in turn reduces the heat onto the CHRA = reliable??
Nov 5, 2016
19
15
Lake Worth, FL
FF was 92, pwm was in the 80's at redline, it stayed pretty low until after 5500.
Peak power was from 47000ish-5200ish which was 10-12* of timing, so less than a bms e85 flash. As boost/cylinder pressure drops, you ramp up timing to try and keep the cylinder pressure up. Standard practice. 14.2* at 6500. 11.8ish afr down low, 11.5 up top.
Timing is stable due to the vanos profile. Its much different than the BMS OTS flashes. The needs are different in every scenario.
Twisted Tuning
Oct 25, 2016
982
915
www.twistedtuning.com
N54 and N55 Cars
running turbos at their limits for extended periods of time is never recommended. People do it, but most of the people doing it only spend 2% of the turbos mileage at that power level. Doesn't mean they are meant to sustain that or will. And no one really monitors Exhaust
Good numbers nonetheless, @Justin@BoostAddictions any knowledge of what the IATS were?
Reactions: Hotrodmartin
Nov 5, 2016
19
15
Lake Worth, FL
The pull started at 101* and ended at 111*. This dyno is outdoors in open air, the temp according to the dyno was 96.21* and 31% humidity.
What is your baseline dyno OP?
I don't think we have one for this car, but a FBO+inlets 335is I did on e50 base lined at 310ish i believe on map 0
Reactions: Twisted Tuning
Cheezy
611
225
Toledo Ohio
Dang that's hot! IAT were low for that temp. Any idea what fmic he had?
Steamboat
The baseline was around 450 without the pi set up. As soon as the maps were sorted Justin was able to push the tune harder.
The Fmic is a vrsf 7". I'm very happy with its performance in the Florida sun, and the wider inlet ID fits nicely with the wider mmp outlets. It's a very tight fit.
I don't have a b3 flash because I haven't gotten around to it. If you'd like to flash it for free, I'd be glad to accept :)
The trans has around 2500 miles, with 3 flushes already :-/
