Stock rods vs torque ?
SlowE93
1,829
Just a plane ticket away !
E93
Question for tuners and vendors / builders. What is max "safe" torque at 3k, 3.5k and 4k ?? I see different turbo companies bragging about how fast spool and torque with X brand turbos. The majority of people are on stock rods so kind of pointless it seems. Meaning on stock internals, many of us dont need the crazy fast spool as many advertise and can go with XX brand instead that spools slower for a happier engine. So whats max torque as asked above ??
1,152
1,203
Scottsdale, AZ
There is more to it. Remember, spool and lag are not the same thing. Spool is a function of rotordynamics, it's where in the RPM band you have enough system efficiency to make boost, which is torque, which is power (when considered at a given RPM). Lag is a time function, i.e. when do you make the power after you request it. I like the "time-to-torque" description, but really responsiveness is what we're describing. A dyno does NOT show lag. Let me repeat this. A dyno does not show lag.
While spool and lag are not the same thing, they are in bed with one another. Often times quick spooling turbos are low-lag. Conversely large turbos that don't spool until 5k rpm are never going to be responsive.
It is true in one sense if you just put a larger turbo on, and it doesn't spool until late in the RPM band you're not going to pretzel a rod as easily, but you're also completely ignoring the value of a responsive system. This is NOT important for drag racing with staging, launch control, NLS, etc. but it IS important if you actually drive your car on the street (or road course) and want something that doesn't feel like dopey is sweet talking your turbos into doing something when you push on the skinny pedal.
Smaller low-lag turbos that have boost intentionally brought in slower down low to save rods will still be much more responsive than a large turbo that gives you the same dyno curve through that RPM range. This is why we keep saying that the end-use turbo choice really depends on many factors, mods, fuel, transmission, end use, power goals, etc.
As for how much torque on stock rods, we've seen customer stock engines last quite a while rolling boost in a little slower to keep things about like this dyno example below, personally on my own motor I would go less aggressive:
SlowE93
1,829
E93
Thanks a lot for the detailed reponse. I appreciate it. As it sits now, my car on the dyno shows
3k 450
3.5 525 then ramps slowly to peak 545 at 4.4k
I saw a stock internals dyno with same torque at 3 and 3.5 and by 4 k it was at 600. So was wondering what is considered safe for N54 stock internals.
Oct 24, 2016
1,152
1,203
Scottsdale, AZ
It's not going to last forever at those torque levels, I posted about the max I would run... but if you're going to run it, make sure it's running well -i.e. this isn't the place to be borderline on timing targets or running out of fuel. We've seen stock turbo cars bend rods with ridiculous timing targets, boost mountains, or severe misfires.
The issue you run into is you can't just tell your tuner I want to make under XXXHP at XXXXRPM. You would have to be on a dyno during tuning to do this accurately.
You can say I want to be at XXPSI and XXXtiming but it is more of a crap shoot as to what power you are really making at that RPM.
It is funny to me that people are coming to this realization after literally years of vendors touting that their twins were the best because of 'gobs of low end tq' as a major selling point over single turbos etc. Even to the point of showing dynos which would potentially bend stock rods, of course a word was never said about that ;)
tisdrew
179
91
09 335i 6MT
That was my point. Next, where can I get good axles ? Snapped mine yesterday on a 2nd gear pull.
You can get replacements for cheap from eeuroparts or others by googling the part number.
Alternatively, both DSS and MFactory sell "1000hp" axles.
rev210
244
335i - 08 Coupe .
Anyone else running these axles ?
Yes . Have them in mine after destroying an axle . Bolt in nicely/ easy . I am running pure stage 2's / PI / st3LFP/ E60 ./ Built Nizpro AT (billet shafts etc)
Reason I chose them over DSS , bearing carrier is better , billet smaller diameter shaft etc.
SlowE93
1,829
E93
So back to topic, anyone else ? Whats max torque to make at 3k, 3.5k, and 4k ? Or share dyno sheets and some info on how long motor has lasted ? Where would most like to see PEAK torque in the powerband for a stock internal ?
I think this might have a dozen different answers that all might be accurate just depending on who you asked.
When you view the vehicle as a wear item, something that will eventually wear out and doesn't last forever, the most important question should be, how long do you want the vehicle to last.
Reactions: saskatchewan135
SlowE93
1,829
E93
The earlier you see peak torque the faster you will have issues. Each motor will handle different amounts of abuse depending on age and maintenance
That is understood. But taking maintenance and mileage out of the equation, the question SIMPLY remains, how much torque is TOO much torque for a stock internal N54 and at what rpm ?? Say 550 at 3.5 k and climbing to peak 620 at 5200 for example. Peak SHOULD be ok at that point, but is 550 at 3.5k ramping up too soon ? Or is 620lb ft too much regardless of rpm for stock internal N54 ?
There has to be a point that tuners try and avoid for longevity/reputation/and overall customer satisfaction ???
SlowE93
1,829
E93
I understand there are variables. How about this , what realistically would be a recipe for disaster as far as torque vs stock rods ? Chris already gave his take on the dyno I grabbed off the net. Any others have opinions regarding that dyno sheet ?? As I did some digging, I believe that dyno is stock internals and professionally tuned by a reputable tuner.
Asbjorn
856
607
European, based in China
Z4 N54 DCT
Whereas I do not know what a "safe" or "reasonable" limit is for the N54, I do want to somewhat comfirm that it is possible to tune a smaller turbo to "hold back" at lower rpm, and get the best of both words (ie low lag + low wear). At least I am pretty excited about what my tuner is doing with my car. I believe you actually have to do this on DCT cars to keep the clutches happy.
Here's a virtual dyno plot from a pull I did today slightly up hill.
24304
Here's the torque projection from MHD:
