Parts Required for M3GTS conversion in 135/335.
2,251
804
Parts for the GTS conversion are as follows be aware that some of these are pre/post LCI and you need to get the one for your car...also the trim is LHD/RHD specific, govent the audience is majority LHD ive posted them.
GWS 61317842102
Drivelogic button 61317835039
6 Pin Connector for Drivelogic button 61132359992
8 pin connector for GWS 6113695426
DSC/Power/EDC switch for console 61317841136
and non EDC 61317841135
Shifter with leather boot 25122283705(on eBay these fetch 150USD but ECS has them brand new for 199 ;))
Trim panel pre LCI (there are different ones and i can’t get real OEM to show the LCI ones with CIC trim
http://www.realoem.com/bmw/enUS/showparts?id=KG92-EUR-01-2011-E92N-BMW-M3&diagId=51_6635
Okay, so this is a tempting project. The problem I have is the clarity on the clarity of what rear differential ratios can be used with it currently?
@doublespaces i can’t find the 8pin plug number where’d you post that?
Does anyone have the drivelogic button part 6 pin plug part number ?
I only have the 10 pin plug part number for the non M3 GWS
2,251
804
Forgot you’re doing the stock DCT conversion not the m3
2,251
804
I need the one for the drive logic switch which i believe is 6 and i need the 8 pin thats on the GWS.
From @dyezaks thread
The M3 GWS plug 8 pin
and also this one for the drive logic
He called it a six pin and that is what the diagram shows as well. ??
Ah sorry, I didn't see he was asking for the 6 pin also.
Gotcha. well the 8 pin I can't help with, I don't think they sell it and if they don't I don't think anyone knows the part number, that is my understanding anyway.
2,251
804
Been told that the M5 shifter will also work but won't fit the centre console trim and so may be an option for those like me that don't want to do the whole console trim.
Looking at how @Redi132kw did it, it looks nice though so i might do that
1,066
61136954526 ? it is listed in the realoem diagram and ECS has them in a 10 pack.
the one in your picture is also used for the dome light so may be easy to cut out of a junker
2,251
804
My part provider has everything (used) just need to put the dollars together and get this all fitted and coded. Cant wait !
Hope the part numbers help people !
I want to do this for M Drive as well - But we need someone to be a guinea pig and get it working first. Im looking at you @LMB335is ;)
Eventually we'll have the part numbers the guide on how to physically install it all and then a guide to coding it up which i hope to combine into a single doc.
Reactions: Stokes
