Ok I went to install my lsd today and the finned diff cover won't fit because I'm convertible. It fits but would require cutting a bunch of fins due to the extra brace that is there.
I had a one-off lockdown brace made for this finned cover by @PC Racing and will sell it all together for anyone who wants it.
You'll get the 650i finned cover(with drain hole) a spacer, the diff lockdown brace( normal braces won't fit) an extra cover bolt, a 10.9 grade 130mm bolt and a couple other bolts for the brace. Selling at a loss:
https://bmw.spoolstreet.com/threads...own-kit-and-necessary-spacers-and-bolts.1710/
ATL-IS-N54
261
61
ATL ga
You'll get the 650i finned cover(with drain hole) a spacer, the diff lockdown brace( normal braces won't fit) an extra cover bolt, a 10.9 grade 130mm bolt and a couple other bolts for the brace. I just want what I paid for it, lmk if interested.
Wish mine had drain holes... makes the fluid change interesting to say the least
ninjacoupe
91
73
If this is still on I'll be number 20
08 135i MT welded 3.08 full pumpkin
13tx-IS
19
13
2013 335IS
Id say you better call them mond morn.
But they arnt too speedy checking out the cores.. They got,mine fri last week.
Said it would be checked by tues.
Called thurs..and still work in progress..
Reactions: ATL-IS-N54
ATL-IS-N54
261
61
ATL ga
Changing the fluid post break in on car #2 Torgo SGO 75W90
BMWE92_Harry
62
15
N54 E92
For those that opt for LSD only, did you guys get the new diff gearing, shim kit, diff bushing?
13tx-IS
19
13
2013 335IS
Can we get an update on the status of the Core checks and deposit refunds. Been a week since I was told it would be checked out and still nothing. It would be nice to know what part has taken place.
I'm getting in on the action as well. I just bought a bolted 3.08 diff that is getting sent directly to Mfactory.
Nice! I did the same thing but with a 215mm 3.46 diff. It was built in 2006 and had 35k miles on it and cost me 200 shipped. They only made those for a year and its production date was earlier than synchrotech's chart.
ATL-IS-N54
261
61
ATL ga
I've got mine and mine showed up after yours... mine showed up in PayPal yesterday and bank account today... start a NEW convo with @MFactory and push your questions through...
Arrived on the 1st, so 8 days
Bmwfixerguy1
875
292
07 335i MT
Has anyone with larger hybrids (stage 2 flavor) or ST gone from a manual 3.08 to a 3.46 ratio? Thought I would see a lot more of this but not as popular as one might expect. Maybe for a specific reason?
335i_nick
98
43
Higher gear will make it even harder to get out of the hole. Way harder with hybrids
