Looking to hit close to 800whp. What setups am I looking at ?
twinturbos
291
79
E92 335i MT
Hi,
I am running a docrace 6266 build. Plan is to build the engine over winter: pistons, rods, studs, bearings, valvetrain. Looking to get as close as possible to 800whp. I have access to 94 octane and am running a WMI setup currently right around 600whp. What are my options to push 800whp after the engine is built ?
E85? A bit complicated to get so if I really have to go this way I'd like a E30 or E50 mix.
PI+
Spool overdrive hpfp ?
VTTO shotgun ?
What's your optinion on what the best setup would be best ?
iminhell1
419
207
E85 or race fuel (110).
Spool 4x (unproven) or DBBL (proven), if DI only. PI can also be done and is well proven; various options using JB4, Split Second or something else.
6766 (proven)
Ditch the WMI. It can't support the power.
Reactions: tisdrew
Hi,
PI+
VTTO shotgun ?
Are you going to sleeve the block?
tisdrew
179
91
09 335i 6MT
I may be out of the loop but I believe the only way to hit 800 is to go with port injection at this time. With good head porting, you may be able to eek out more power with less boost on your pump gas octane and I think octane will be a limiting factor. Your engines compression ratio will be a factor in how much boost you can run before you get knock -- consult with your engine builder and tuner as I am neither.
I would think a PTE 6466 could do it but you might be octane limited. You can go bigger like 6870 or go with other turbo options like GTX3584RS, GT42, EFR 9174 depending on your brand and power band preference.
nyt
335
2010 335xi
The 6266 should get you close to 800, the 6466 closer to 900. the 6870 is a bit big imo, limited around 1100.
Scorpstan
112
130
6870 will never hit 1100 on an n54...probably not even 1000
i have close to 1k HP with 34-34,5psi. and still have room for improvement 🤔
head is stock.
Hi,
PI+
VTTO shotgun ?
with the 6266 you will need 35-33psi, 12-14ign (with 100% WMI mix),
but better with e50 fuel with Helix or Shotgun and small PI,
min. stage3 intank fuel upgrade. better stage4
tisdrew
179
91
09 335i 6MT
Yes, but I believe those would be E85/race fuel numbers. Given that limitation, a larger turbo with less psi and less heat might make the power he's aiming for. I've seen two local 6870 setups and neither of them broke 900 and that's with E85. I obviously don't know specifics but they had more money into their mods than I had into the full cost of my car lol
nyt
335
2010 335xi
800 on 94 octane and wmi... good luck with whatever turbo. I'm not sure you're going to be able to do that reliably even with a lower compression engine build.
Milan
413
241
jebi se
your mom
head is stock.
You have close to 1000, but not 1000, and certainly not 1100. I don't buy the room for improvement argument, and please don't take it personally I think this is true for anyone who says it's a "conservative tune" or there is "a lot more in it".
When you went to the dyno to tune your car, you probably didn't set out to do it 50% and call it a day, at least I don't on any of the cars I tune. I'm betting you went as high as you could go before running into other issues. 35 psi you are out of compressor efficiency, I'm sure you could turn it up more, but I bet you are only going to get a few whp per psi of boost.
Basically if you could have turned it up more, you would have
Reactions: ShocknAwe
nyt
335
2010 335xi
What compressor map are you looking at?
Scorpstan
112
130
Well, on that dyno day, my tiny 300cc PI injectors were the limited factor. Now I have 750cc. Tests on the road have so far been successful.
On that dynoday we could also see how the HP increased constantly. Every 2 psi more results in 40-50 hp more. therefore i think that 1000-1100 are definitely possible with the 6870.
but i will see ^^
Reactions: RuskiRacer
tisdrew
179
91
09 335i 6MT
Yes, I think we're in violent agreement :) Just trying to give out some information and advice to the topic creator so he can do the best within the constraints he provided
Milan
413
241
jebi se
your mom
but i will see ^^
So if you run 10 more psi you are going to gain 500 more whp? See how silly that sounds?
Turbos have compressor efficiency maps, you don’t just add psi forever and keep making power. I’m sure you understand this at some level because you chose a 68mm turbo and not a 62mm one.
Milan
413
241
jebi se
your mom
The compressor map of experience from having a 6870 on my car. Precision doesn’t release compressor maps for their turbos.
6870 is not an “1100 hp” turbo. And AFAIK no one has made 1000 whp on this platform without a 72mm+ turbo.
  • Dislike
Reactions: nyt
twinturbos
291
79
E92 335i MT
Nice to see y'all go off like this. Anyways. Need to get as close as possible to 800 on 94 +WMI. Still looking to hear what kind of setups are ideals and if someone has one of these I'd love to hear more/see pics.
Manuel416
Maybe you should be Aware of your talkings, scorpstan has the Most reliable/fastest n54 all around..or show ne Others that deliever on every Event (rollracing) or Post as often new "record numbers" of 100-200, 60-130 etc...not only the numbers of the dynos are important ;)
He knows what to do. And if you look at His powersheet you See that max hp was at around 6500 with a climbing curve, he didnt rev Higher because of fueling,not because of his turbo, as He Said.
nyt
335
2010 335xi
If 2 psi was getting him 40hp... 10psi would be getting him ____ ??
Let's at least math right.
nyt
335
2010 335xi
Oh yes, the imaginary compressor map in your mind. That's the point. You have no real idea when it's running out of steam.
Turbo is clearly good for over 1000.
This is on an S54, but the turbo is making the power.
