Ad: YCW Engineering Sports Axles - Official Pre-Order
BreakMyBillfold
82
34
535 and 335 axles are not the same
Driveshaft too. I thought I was going to be able to use an early 335i bolted diff for my 535i to save on some install costs, until Team MFactory explained that the input is a bolted flange on my car and splined on the 335i.
I couldn't swing a full on diff build using my welded style diff even with the Black Friday deal, but I was able to get in in a SMFW. Hopefully next year or when there's another sale I'll be in a position to get in on the LSD.
SlowE93
1,829
Just a plane ticket away !
E93
Put more power to the ground with the YCW Engineering Sports Axles, designed specifically for the high performance street car.
Diamond Cut to exacting tolerances from Forged High-Nickel-Chromium-Molybdenum Steel
- Perfect fitment & finish ensures hassle-free installation & maintenance, each and every time
Designed using leading-edge Solidworks 3D CAD & Cosmos FEA software
- Advanced Geometry minimizes parasitic drivetrain losses. Race cars utilizing YCW Engineering components transfer, on average, 1-2% more power to the ground over our competitors!
2nd Generation Design
- With our Rifle-Bored Center Shaft, the YCW Engineering Sports Axles are lighter, stronger and more efficient than any other Sports Axle on the market today!
Covered by the YCW Engineering Lifetime, Globally Transferable Warranty
- Whether used on the Street, Strip or Track, all YCW Engineering Sports Axles come with a Lifetime, No-Hassle, Globally Transferable Warranty
We have so far tested these up to around 550lbs with no issues (we don't have an upper limit on these yet). Production on these is almost complete, with shipping estimated to start in January after the holidays :)
Unlike other axles on the market, ours are a Complete Set, including new 6-ball CV joints i.e You do NOT have to send in your existing axles for a shaft upgrade! Our axles are a direct plug-n-play swap
For those asking for the weight, our axles actually weigh exactly the same as the oem (12kg). The reason for this is because our centre shaft ends are a lot thicker, as well have having larger cv cages/balls:
Fitments Available:
- E8X/E9X 135i/335i MT/AT
- E60 535i AT
Fitments Pending Test Fitment
- E8X/E9X 135i/335i DCT, E9X 335d and E9X 335i X-Drive
- We have still to confirm if the fitment is the same as the MT, so we need someone to try. If they don't fit, we will refund you
MSRP: $999.95 + $62 Shipping
Pre-Order Price: $799.95 + $62 Shipping (20% Discount)
Deadline: Pre-Order Pricing will only be available from now until the Axles are ready to ship in January. If you do not purchase during the Pre-Order, the pricing will revert to MSRP
Please feel free to ask any questions, or PM to order :)
You are aware there are a few failures, correct ? Is there a specific batch that are / were bad ? Or are they all the same ? Built at same location ? Same materials, or were they changed at some point ? Breaking axles is not fun and costs money and time. Even if you replace the axles with new ones (which lifetime warranty is great), there is still labor, hardware, getting car towed, etc. and becomes very costly for the consumer.
MFactory
245
140
Yes, we are aware, and have replaced any broken axle under warranty. We have analysed the broken components and have upgraded where necessary (not because of a faulty part, but because we recognise an area that can be improved upon). Once upgraded components are available, the old components are no longer used (be it on a new part, or as a warranty part)
SlowE93
1,829
E93
So my replacements will still be prone to failure ? If so, once stronger ones are out, will these be recalled ? How far out until stronger units are available ? Not looking forward to swapping these out AGAIN or getting stranded AGAIN. Thanks for replying !
MFactory
245
140
They are not prone to failure, no. We upgrade our parts (all our parts, not just axles) whenever we see an opportunity to do so; it does not mean the old part was faulty or prone to failure.
Likewise, we can't just "upgrade" existing customers parts unless their is a clear fault and/or failure. If you do experience another failure though, depending on the part, it will be upgraded to the revised part. For these axles, it was the bearing cage, which we have upgraded to a more durable steel to resist cracking
SlowE93
1,829
E93
Ok, I am getting my replacements in tomorrow according to shipping and tracking. My axles are coming from ECSTUNING as that is who I originally purchased these from in Feb. 2019.
My concern(s) are
1. If this is NOT a revised part, it will fail again, just a matter of time.
2. Since they will arrive tomorrow, can I get these swapped out for a revised part with stronger cage ? Instead of waiting for it to break again ?
3. Unless this is a revised part that ECS had in their posession and I am already getting a stronger axle ???
Highly doubtful as I was told these have been sitting on the shelf for a while when I asked if they had replacements in stock.
4. Another member had same failure, axle, breaking point, etc. as mine. So at what point were these axles revised ?
What month ? What year ? I dont know when you guys realized that there was a weak point on them ???
SlowE93
1,829
E93
Would suck to have to wait and see if I break these, get stranded, pay for towing, car is E93, axles wont come out unless you drop exhaust and support bars that convertibles have, time down, labor, wait an hour for tow truck, list goes on and on.
Really hope you can help me gain faith in these again. I just want to install and forget about them/ not worry about them. Car has been down a week already. Need to get it going asap, BUT would like to do so with revised parts. Lmk what you can do.
MFactory
245
140
Please send us an email and I'll check the revision dates for you on your set: info @ teammfactory . com (without the spaces)
DCook
274
135
08 BMW e92
So were these revised after April and may of 2019? Because thats when both of my sets broke. Along with the shipping wait. Bearing retainer on the outside.
MFactory
245
140
Yes, the last revision (which was actually made to the CV cover to allow extra clearance/capacity) was done back in September.
SlowE93
1,829
E93
What isn't looking too good?
Are you Michael ? I get really confused dealing with Mfactory to be honest. I have dealt with synchrotech, any concerns get sent to Mfactory. Online, I have seen Mfactory (on another site, not sure if that is also you), tell people any issues to contact synchrotech in San Dimas. Just seems like a lot of back and forth. Synchrotech, last time I checked, did NOT stock axles. Would be so much easier to take an hour drive, speak to someone in person, look at any differences in parts, etc versus dealing with a person all the way in Hong Kong and try and verify parts off of pictures. Just my opinion. We will see how it all plays out.
