Injen BMW M240 M340 M440 EVOLUTION Cold Air Intake System **NEW PRODUCT**
Mike @ XPH
Nov 18, 2016
468
98
Las Vegas
Key Features Important: Please verify that your vehicle is listed in the Direct Fitment tab before purchasing. Dyno Proven gains of up to 13 hp and 11 lb-ft. of torque Manufactured from high-strength XLPE Roto-Molded Polyethylene Designed to work with the stock calibration Box seamlessly adapts to the OE inlet scoop without modification Dynamic under hood appearance while maintaining an OE fit Intake scoop integration is designed to capture the largest amount of cool air for max performance Aggressive intake growl under acceleration Simple drop-in installation can normally be completed within 20 minutes Reinforced automotive grade silicone couplers Air Filter attaches to the airbox using our patented TwistLock method Fully serviceable 5.00" I.D. Injen SuperNano-Web dry air filter Replacement air filter part number X-1093-BB Made in Pomona California, USA Injen Technology Limited Lifetime Warranty Note: This product is not currently CARB exempt Direct fit for 2020+ BMW M340i / xDrive L6-3.0L Turbo (B58) 2021+- BMW M340i / xDrive L6-3.0L Turbo Hybrid (B58) 2021+ BMW M440i / xDrive L6-3.0L Turbo Hybrid (B58) 2022+ BMW M240i xDrive Coupe L6-3.0L Turbo Hybrid (B58) 2022+ BMW M440i xDrive Gran Coupe L6-3.0L Turbo Hybrid (B58) Description You finally have your 2020-2022 BMW G20 3-Series equipped with the Turbo B58 and Turbo Hybrid B58 engine and now the next logical step in your search for power gains is with Injen Technology. The EVO1108 is specifically designed for a drop-in fit in your BMW, including the seamless fitment into the factory air scoop. This easy to install performance cold air intake system allows that hungry Turbo engine to breathe deeper and unleash that additional performance that you’ve been craving. It truly is a win on all levels. The Injen EVO1108 cold air intake system is truly on the next level. From the one-piece sealed housing that utilizes our patent pending Twist-Lock technology to securely attach a massive SuperNano-Web Dry air filter in place, to the seamless fitment to the OE inlet scoop, all the way down to premium hardware, Injen has put it all on the board to provide you, the consumer, the best intake possible for your new BMW! Roto-molded Housing: The one-piece sealed housing utilizes the all-new Injen Twist-Lock System to securely attach the SuperNano-Web Dry air filter in place which eliminates the use of unnecessary parts and provides one of the simplest installations available. The EVO1108 housing also sports the all-new Injen Clear-View badge for a cleaner more aggressive under hood appearance. Roto-molded Intake Tube: The EVO1108 Evolution Air Intake System uses a custom designed and dyno-tuned, intake tube to produce huge power gains while retaining an OE quality fit. SuperNano-Web Dry Air Filter: 'That's massive!' is all you will hear about this SuperNano-Web Dry air filter that is included with the EVO1108 cold air intake system. This filter has been uniquely designed to work with the Injen Twist-Lock System. Using our Twist-Lock technology has allowed our engineers to use the largest filter possible for this application, which increases the available air volume, resulting in added power while keeping the installation process quick and simple. Quality Hardware: From the Stainless Steel Band Clamps with an inner protective liner to the reinforced automotive grade silicone coupler, every aspect is covered for a perfect and secure fit. Hassle-Free Installation: Make it easy! The Injen Evolution Air intakes that use our Twist-Lock System have been strategically designed to use fewer parts to provide the end user with one of the quickest and simplest installations available on the market today. Dyno Proven: Clean and simple, NUMBERS talk! Injen has put in the time and diligence to stand behind our performance data. We put in the time to test and prove that we have developed a superior kit for your B58 equipped BMW. After hours of designing and dyno testing, Injen is proud to say that the EVO1108 Evolution Air Intake system puts down consistent power numbers of up to 13 additional horsepower and 11 Lb-Ft. of torque. Warranty Injen Technology offers a Limited Lifetime Warranty to the original purchaser against defects in material and workmanship on all intake systems, air filters, and hydroshields. Injen Technology will replace, at no charge, any intake pipe, air filter, or hydroshield considered by Injen Technology to be defective. Any and all warranty coverage is limited to the repair or replacement of the defective part only, at Injen Technology’s discretion. Proof of purchase is required. The warranty does not cover incidental or consequential damages, damages caused from improper installation, nor does it cover the cost of installation or removal of the defective part or its replacement. All warranty items must be sent freight prepaid with a valid RMA (Return Merchandise Authorization) number and copy of original invoice.
