VPG 777 WHP DI ONLY
Oct 24, 2016
1,152
1,203
Scottsdale, AZ
While all of you have been thinking about what to get Tony and I for Christmas, we've been diligently working on doing what we do best; pushing boundaries. I'm very excited to give some details on our latest accomplishment. Specifically, 777 whp on Direct Injection only. We didn't just break our previous DI only record, we destroyed it.
Not a lot more need be said other than we got 777 whp (uncorrected; std was 772) out of our shop car with no port injection used. That's right. Direct inject only. We used our off the shelf double barrel shotgun system which is matched with our special VTT/SS hpfp controller. That's it.
At a Glance:
Uncorrected Graphs:
DI only, 777 whp /701 wtq
DI only, all dynos
STD Graphs:
DI only, 772 whp / 697 wtq
DI only, all dynos
Log Screenshot:
Quick History:
To refresh your memory, back in June Tony was able to get 650 whp with our proof of concept prototype hpfp system. That was exciting from a theoretical perspective but many of you were mildly cranky that we didn't have a hard date on turning that proof of concept into a viable product. We heard you.
The Car:
E90 335
Forged Rods and pistons
Stock head
VTT GC Turbos (http://performance.vargasturbo.com/bmw-products/n54/)
VTT silicone Inlets
VTT silicone Charge Pipe
VTT Custom PCV System
VTT Crank Breather
BMS Downpipes
Custom Dual 3" to 4" exhaust
Custom LPFP setup
VTT Double Barrel Shotgun
VTT/SS HPFP Controller
Custom tuning by none other than @V8bait (Justin)
NGK 5992 Plugs
M3 rear end swap with 3.15 FD
DSS Custom Carbon Driveshaft
Stock 6MT
PTF Twin Disk Clutch
100% E85
NO PORT INJECTION
More Details:
This is possible with our off the shelf VTT Shotgun Double Barrel, our controller and some flash tuning changes. It shouldn't be a surprise to you that at this level the system is VERY sensitive to fuel system health and capacity. Every aspect of the fuel system must be in absolutely tip top shape to even come close to this DI only.
More questions? Ask away. We're here. If we aren't, it's because we're testing.
Oct 24, 2016
1,152
1,203
Scottsdale, AZ
Could someone run say a stage 3 or 4 lpfp setup along with this?
Sure! We have the custom LPFP solution in place which I'd bet significantly outflows a normal stage 3 offering, but I'm not sure how it would compare to the new stage 4 offering -that's not something we tested. Bottom line is that you're going to need a stout lpfp solution at these levels, no two ways about it. How you get there is up to you, but obviously it has to flow enough.
This is very impressive. I'm curious if you'll be testing this fuel setup on GC+ and how much fuel you think you've got left? Rail pressure looks nice at 7k.
AzNdevil
605
291
Hong Kong
care to share more details regarding the hpfp controller? seems it would be the best solution for peeps like me that dont want to go PI and no access to ethanol....
TwinTurboWagon
228
244
San Diego
Awesome. First of all thanks of the information and formatting of you post, there is well organized information to back your claim.
Regarding your statements about "your fuel system must be in tip top shape..."
Is this double barrel + HPFP controller any more sensitive to fueling issues than say a common dual pump LPFP + PI setup at these 600+hp power levels? It wasn't clear if a well-working fuel system is even more important or rather important as always.
In for more details about the controller.
Congrats on this achievement, personally I think this is a HUGE step forward on the platform.
Evan
R.G.
668
328
Henderson, NV
E92 335, F10 M5
Nice. So the big question, approx when does this set up run out of fuel? 3500 psi at those levels is nuts.
A secondary hpfp needs to be purchased with the kit and the controller is modified? If so and customer already owns a SS, would you guys be willing to modify or need to purchase the in house unit?
Flinchy
49
15
Won't help much if you have no access to ethanol. The whole point of getting more flow out of the DI system is it Taps out on e85 with conventional setups pretty fast
Flinchy
49
15
Can we expect any more info on the controller/tuning setup any time soon? Pretty huge deal if you can now properly control both hpfp's as well as get the injectors to flow as much as they possibly can.
AzNdevil
605
291
Hong Kong
hmm... so you are saying i will hit pump gas octane limit before i hit hpfp limits?
Nov 5, 2016
615
625
Bay Area
Its simply a Split Second controller we had made for us. Anyone already with a Split second controller can do the same, but you will have to cut, and splice wires. The only difference is ours plugs directly into the second HPFP. Nothing different besides that. As for flash tuning changes, its a matter of changing a few existing tables to suit high power levels with no PI. No additional tables are needed, all this speculation on IPW tables being needed was wrong, I said that too, so I have to eat a little crow. Basically anyone's car with a healthy fuel system, a LPFP set up that can provide the fuel, and our double barrel can do this.
Nov 5, 2016
615
625
Bay Area
Details are 2.5 years old, here http://www.bummerboost.com/showthre...grade-and-a-new-stock-frame-horsepower-record
As stated above simple Split Second controller plugged into the Second HPFP, with a custom map. This is the SAME kit we have had for sale forever, the only thing that has changed is we found a better way to control it. We are still in negative trims at these levels, meaning on DI only 800WHP+ support is handled by this system
Nov 5, 2016
615
625
Bay Area
Evan
Yes, its more important. If you have a injector that is even slightly questionable. On PI you can get away with it as you are not asking them to do so much, this system will find any weaknesses in your fuel system, but I did find under 30 psi, its not nearly as sensitive, I was making in the 740-750 range over, and over, and over on about 27-28 psi, when I turned it up a little bit, I had to swap two injectors to keep it out of fuel induced misfires. The more boost you run, the more sensitive it becomes.
I'm curious to hear more about it. And when you're ready, I'm interested to see how much more fuel there is. As I said before and is obvious, rail pressure looks fantastic.
Nov 5, 2016
615
625
Bay Area
Can you let me know what more details you need? The post above has all the details on the Shotgun systems, and we have no idea who much more capability there is, the trims are still negative, meaning we have at least another 50-75WHP I would assume prob closer to 100%. As for the above statement about splicing wires, I also forgot we had harnesses made to go from an EV-6 plug which is 99% of the N54 pi controllers out there to the HPFP, so you would just need one of those.
Yeah just the minor details, I guess I'd just need to get in touch with you about the shotgun. Since I know you're always pushing, when can we expect you to put the GC+'s to the test with this setup?
R.G.
668
328
Henderson, NV
E92 335, F10 M5
I think the original appeal was maintaining DME control
Now the PI comparison looks like this
$1200DB vs $900 rail
$700 hpfp vs $100 Walbro
PIA install vs Easy install
$1100 oem injectors (replacement cost only) vs $400
SS controller vs SS controller
This is much cleaner as far as retaining factory look / function but definitely not the most cost efficient.
Maybe I'm missing something
