VPG 777 WHP DI ONLY
ATL-IS-N54
261
61
ATL ga
Everyone forgets the GC's bolt on to all RHD cars, we have quite a few people running them. Can have this exact set up on your RHD N54...:)
Yeah u RHD guys can buy stock location Twin replacements to fit at least... Are not totally out of luck... I'd rather have a fast spoiling set of twins anyway, and limits to what 7-800whp? Why even go single when so much is involved ?
4,331
Some people dream big :)
Also, there is the reliability argument.
AzNdevil
566
269
Hong Kong
The reliability argument is a big point since I can't work on my own car. So... if the turbos go and even if I get another pair from warranty which seems pretty unlikely from all the posts I have read, I will need to pay for install and it's not cheap....
Last time I did the math it comes out to ~5k for hybrids and parts and install.
If I will run out of octane on 93 pump gas, with no access to E85 and limited access to meth at a premium price... the price/performance ratio for upgraded twins/ST goes down even more... but this is a limitation on my side so I am not going to bitch about it ;)
For anyone in the same situation reading this, direct port meth injection with something like a Aquamist HFS4 kit to bring the octane up and either get stuck with FBO + in/outlets and hope for the best or upgraded hybrids/5862 ST would be the solution.
Abacus38
643
385
Tampa/Orlando, FL
2007 Ti Ag 335i
A 58mm turbo is small single turbo. Generally speaking the bigger the compressor wheel the more efficient it is. 67mm turbo has a 10mm larger inducer and generally modern turbos that size have a 78-79% efficiency rating compare to a 72% one a 58mm
rac
341
204
135i ST
any of the rhd customers provide feedback with photos or what was required for custom fabrication (outlet) on the rear turbo?
R.G.
668
326
Henderson, NV
E92 335, F10 M5
Is there an ability to fine tune pressure to allow the operating range to stay in the 150-175bar range with the controller? Or is it more of an on/off?
08_335i
371
215
2008 ST 335i
I am in the same boat as you with having no access to E85. I run as stated, port meth injection with a 5862. I'm at 5300ft elevation which adds another factor in. I can usually run around on 23psi without much of a fit timing wise, sometimes It'll let me run 26psi on the setup. I did get to play with about 6 gallons of E85 to a full tank of 91 when I went into boise a while back, now that was fun to crank the boost up on, so fun, my AT started failing :D
Reactions: AzNdevil
Flinchy
49
15
I didnt know you'd actually finished making them 100% RHD bolt on and confirmed fitment etc!
So the RHD rear casting is all done, and you don't need to swap the water line either?
V8bait
500
773
Texas
With the GC I thought replacing the turbos was simpler than OEM, due to the way you can separate the manifold from the turbocharger? At least it's something.
Oct 24, 2016
1,152
1,202
Scottsdale, AZ
A bit. The big advantage is if you wanted to swap out from, say, GC lites to GC's. You can leave the manifolds on the car; remove the v-band, oil and coolant lines, change in the new turbos and remake the connections. That saves quite a lot of time.
titium
48
9
Can the double barrel be run without overdriving either pump? Kinda think this with gc lites would be a pretty crazy Street setup!! Don't really need an over driven pump
Nov 5, 2016
615
624
Bay Area
I'm not quite sure you understand how the system works. The shotgun is able to flow the fuel it does because the pump is overdriven. We have not had a single pump fail in 2.5 years from being spun on the belt. The only people questioning over driving the pump are people who have never run it. Its a great system, and extremely reliable
rac
341
204
135i ST
i followed up on a rhd install, the compressor housings and outlets to FMIC required custom fabrication for it to all fit satisfactorily.
you in melb. or syd?
Nov 5, 2016
615
624
Bay Area
This is actually not the case. Nizpro modified them as they wanted to do it a little different. The RHD housings will fit perfect with either the RB Silicone charge pipe, or a custom charge pipe. No modifications are needed to the compressor housings at all.
titium
48
9
Ok so overdriving is required for it to work. I merely thought the flow of 2x hpfp driven at normal speed would be sufficient for my needs.
When you say perfect fit have these actually been test fitted yet or are they just eyeballed? - "ahh yea that'll work"
I know of one person in Australia who ordered in Nov last year and is still waiting for his turbos to be shipped he has the RB outlets ready to go.
Reactions: DirtKurt
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
Could you please address the review which was posted earlier in this thread? http://www.n54tech.com/forums/showpost.php?s=d11866c0a65dcbf291e491c47b720b3b&p=483826&postcount=15
Specifically the part where he says he went through 2 HPFPs. @Chris@VargasTurboTech I saw your post asking the customer to contact you. What was the outcome, was the situation resolved?
I am interested in running a shotgun kit, but if reliability is an issue I won't hesitate to wait for Syvecs for PI.
