Ad: Trans cooler kit
1,923
662
The shroud stays on. I just drill a bunch of holes behind it so air can flow.
Should I order through you or the link? And what was that other guy saying about not including fittings? Last I have a 09 msport does this remove a brake duct or something I have seen comments but i wasnt sure cause i could see the 335is maybe but I thought mine should be ok
1,923
662
Does anyone remove the plate blocking fog light grill on msport bumper I am trying to find if their is a way to make look like the passenger side duct to the oil cooler or if 335is fog delete is only way to go
