Ad: Gen1 B58 ZF8HP70 Swap Kits Stocked in the USA (HP50 to HP70 Conversion)
trevorjelam
Jul 18, 2021
13
CLICK HERE TO VIEW THE KIT CLICK HERE TO VIEW THE KIT CLICK HERE TO VIEW THE KIT CLICK HERE TO VIEW THE KIT CLICK HERE TO VIEW THE KIT CLICK HERE TO VIEW THE KIT
BIMMERBOI PERFORMANCE Is Proud To Announce will be stocking COMPLETE ZF8HP70 Direct Swap Kits Here In The States!!
These kits will come with everything you need to bolt on an hp70 upgrade directly to a RWD car! And we are designing the needed custom cross member for X-drive! Kit Will include imported ZF8HP70, Torque Converter (higher stall), Rear Trans Mount, Flywheel, and optional Coding Service for the Install! **NO CORE NEEDED**
As we are working on a custom crossmember mount for the X-Drive cars we will stay in touch with our X-drive Customers to offer the item once available (cost to be determined)! For the X-Drive cars once the cross member is sourced, you will just need to have a local driveline shop adjust your driveshaft lengths accordingly. (RWD Cars crossmember and driveshaft adjustments are not needed).
Please install a new pan/filter kit and fluid during your swap!! FCP EURO Has the Pan and fluid available!
The HP70 Trans is rated for loads more of torque and hp as it is the stock trans in the diesel BMW's holding up to even tuned diesels! Vs our HP50's measly 500nm rating that we start to see catastrophic failures around 600-650ftlbs.
We supply all needed parts to carry out this upgrade for RWD Cars as a turn key solution, and even have a shop In Redmond Oregon Prepared to do install for those interested!!
Our Coding option is available by BimECU The leading company in bmw coding/programming. They will Remotely code the new transmission into your bmw, for coding you would need a laptop with windows, and ENET cable (or MG/MHD Black WIFI adapter + Ethernet cable) and Good internet connection, not the phone hotspot. BimECU will take care of the rest!
**THE FREIGHT DELIVERY REQUIRES A COMMERCIAL/BUSINESS ADDRESS** Orders will be canceled for shipping information provided to residential addresses. (If you are planning to install yourself ask a business/your place of work/Or your buddies shop to accept the delivery for you before hand)
For Shipping Requests Outside of the Lower 48 States Please contact us via support chat or message us on Instagram here.
