Solid motor mounts - how bad is the NVH
8900120d
22
hi guys, im looking to buy a set of Turner solid motor mounts for my track build.
ive already got MS solid subframe and diff bushes, and poly bushes on all the arms, UUC trans mounts, and a SMFW so i do have some NVH :D
does anyone here have the Turner solid motor mounts? the n54 is supposed to be very smooth when the idle is raised, but will a notice a huge jump in NVH from solid motor mounts?
The Convert
1,487
1,054
Until I swapped the stock dmfw for a smfw I didn't really notice the NVH increase. I'll sell you my old PTE/Motiv solid mounts.
Reactions: Mack0917
berns
175
266
'09 135i
I run the AKG 90A motor mounts. Definitely feel a lot more, but as others have said, bump the idle and it's not so bad. There's no way around increasing NVH significantly when touching the motor and trans mounts. the stuff out back doesn't have much effect.
