M3 Control Arms installed.. Is this normal?
Neophyte
156
67
08 335i
Hi all,
I installed m3 front control arms on my e92. It was fairly straight forward torqued down while under load.
Just went for a quick spin around the block to test but the steering feels really unstable like the steering wheel is wanting to throw itself in either direction. It's just way out of alignment i'd imagine? Is this normal after installing these? Booked in for alignment but not till Saturday.
1,666
Hi all,
Try to eyeball the steering rod ends until the front wheels are more straight forward. Will make the car safe to drive. I really don't recommend driving until either aligned or you eyeball the rod ends. Get a tow.
Reactions: Neophyte
Subwoofer
267
48
Hi all,
Curious to know what is up to date here? Did you ask for a 335i alignment or m3?
KClemente
312
165
E90 335i
I hate alignment shops for that question you asked. Normally for a better balanced car, you would go for M3 specs but a lot of alignment shops will straight up refuse to do that because you VIN doesn't specify those numbers you gave.
And if you do somehow convince them, they'll charge you even more for a custom alignment.
Reactions: Neophyte
1,630
Assuming you know how to adjust the tie rods (toe) you should be able to eyeball a “safe” alignment. Also, if you don’t have camber plates, give yourself max negative camber by removing the small set pin on the top of each strut mount under the hood, loosening and moving the strut tops as close to the engine as they’ll go before retightening. Then go get your alignment at a race shop, telling them that you want the negative camber.
Reactions: Neophyte
Subwoofer
267
48
So front control arms requires an M3?
Neophyte
156
67
08 335i
It's all within the 335i alignment specs, apart from the front negative camber which is in the red. which I told them it would have more neg camber due to the M3 arms. Fronts are currently -1 degree.
Neophyte
156
67
08 335i
Cheers. I only found out about the strut top was adjustable after the alignment. Not sure if they did any adjustment there or not.
KClemente
312
165
E90 335i
Did your alignment fix your unstable-ness? I just installed M3 thrust arms, preloaded them and anything over 60mph and the car is insanely unstable (definitely toed out) and the car just wants to shake me to death. Did your car shake badly before your alignment?
I've already got my alignment appointment so I hope that fixes it.
Neophyte
156
67
08 335i
Indeed! Feels planted. But didn't notice any shaking. Although i was taking it easy to alignment shop.
Reactions: KClemente
KClemente
312
165
E90 335i
Oh okay at least it feels stable. My theory is that my old control arms were so loose that it was just vibrating instead of the wheel. Like if you hopped in my car right now without me warning you about the shaking, you would literally think that the wheels are about to fall off.
I have read anything from control arms (unlikely) to tie rods (fairly tight on mine and replaced whole rack with a low mileage one) to wheel bearings (216k miles I believe)
Wheel bearings is a plausible cause as the shaking mildly gets better when switching lanes. But I digress. I'll report back after my alignment
Reactions: Neophyte
