/FF/ N54 Billet Intake Manifold
A4RingedONE8T
82
134
Just wanted to share the final revisions on our intake manifold. First production manifold will be leaving to Tony in the next day or two for his manifold testing. Updated and tweaked a few more things, moved it up to our larger plenum as it seems everyone thinks this engine needs a larger volume. Pulled a little more weight out of the plenum and gave it it's finishing touches and vac connections. Fuel Rail finalized and perfectly fitting around stock rail. My first batch of manifolds are already sold but have more billet coming tomorrow morning to start another 10. Visit our website www.Fab-Factory.com for further info. Appreciate everyone's following
-Shawn-
Reactions: Jeffman and 08_335i
Rob.K
15
Fort Saskatchewan
Looks great! I do have a question though, where's BOV meant to go? Or is that up to us to get fabbed?
"Requirements for installation, not included with manifold:
  1. Cold side charge pipe modification to meet new throttle body location. Use our /FF/ Throttle Body Adaptor for your fabrication needs. A 3" pipe can be welded direct, or use a 3" slip fit silicone and T-bolt connection. "
Erichale77
827
447
Clearwater, FL
07 E92 coupe
You will need to lengthen throttle body wiring and fab up charge pipe. Mine looks like this...IMG952946.jpg
Reactions: Rob.K
Kervio
43
15
Gorgeous manifold! At first glance I had to make sure it was an n54 bay without the ugly plastic manifold....
A4RingedONE8T
82
134
BOV and map sensor will fit in the cold side charge pipe still.
That is gorgeous. Really nice piece there guys.
Thanks Chris, look forward to your comments once it's in your hands!
I've made a few N54's not so ugly in my time =D
What about fitment with a Drivers side coolant reservoir?
Fits perfectly fine!
Here's a picture of one of my sheet plenum manifolds (same TB location as the billet version) showing the drivers side mounted coolant tank, as well as a full charge pipe - IC to TB
