EKP Active Cooling
pbondar
430
245
I got the stg 2.5 lpfp with walbro 535. I've read the 525 is harder on ekp and that the 535 draws slightly less amps than 525 pump.
They're the same ekps just different amazon vendors I believe. Et3 ekp is the only one that's been physically upgraded. Now how much longer will et3 last compared to the others idk. But For the price of et3 stg 2 you could buy minimum 7 if not 8 $50 eBay ekps, Which seems to last for many people with upgraded pumps about a year.
Well I guess I’ve got all bases covered..got 5 eBay EKPs AND a ET3 unit..I think the good news is that the EKP on Z4 E89s is bolted to a metal bodywork structure in the boot (trunk)…so heat conduction plus convection much better than other E series cars?
Reactions: BryaN54
3,593
I actually did some sleuthing on this. Here's what I determined. I didn't do the 525 simply because it's amperage requirements make it a non-starter with the EKP. The 450 is right on edge, and the 535 has a bit of headroom:
Reactions: wheela and BryaN54
BryaN54
9
Right on that was a great read! 👍 My goal is 500whp on di only hopefully with no hpfp overdrive system or belt driven high pressure pump on hopefully just 93oct
BryaN54
9
So basically he gives you two options cut existing wires or you can upgrade wires up to 10g. He doesn't provide any wires with the kit this is all you get, idk about the Welch's tho my mom always told me not to eat candy from strangers.
Because of the warranty sticker I don't think I will open it yet. I see how he's done it tho the terminal block is on its own PCB with what looks like 10g direct to board. Construction is better than expected. Curious if his 2nd PCB for terminal block has any components on it or possibly it's how he wires the fan into the circuit.
Reactions: Torgus and wheela
BryaN54
9
My ekpm2 still works just wanted to upgrade to ekpm3 so I can apply voltage fix since I have iDrive and I don't want warnings on it and hopefully this will be a good permanent solution for me since my goals are just 500whp.
978
We should run it sometime. I make 500 too my cars manual tho.
Reactions: BryaN54
Asmo
43
37
You can apply voltage fix on ekpm2, you don't have to upgrade to ekpm3
BryaN54
9
After weeks I have completed gathering all the miscellaneous shit to complete my lp fuel system upgrades. I needed to buy so much supplies since ET3 designs doesn't provide any wiring with their ekp upgrade. ET3 also doesn't include much information in the instructions on how to do the new upgraded wiring for it so I had to do some research, with that I discovered that I could use one of the unoccupied Mak8 terminals on the battery's power distribution box for the B+ input power. this provides a more oem+ install and only $25 CAD at the local dealer onto my budget. I bought the last one in Canada atm according to the dealership lol. With the battery to ekp connection done, I then looked into where the factory ekp ground is located for my e93 its behind the rear seats door card/armrest piece. Next i'll need the output power from ekp to the fuel pump with completely no instruction on how to do this connection , and with melting top hats being an issue I know I couldn't use the oem connection. So I deleted the factory connection and added fuel safe radium engineering bulkhead terminals. This required drilling my brand new PR Stg 2.5 lpfp, something that is mentioned nowhere in the instructions lol. I have Two pairs on +/- left if anyone would like a pair of terminals. To go along with the precision lpfp I bought their upgraded fuel lines and the new v2 FPR and filter. I am using 6mm OD Teflon (PTFE) tubing and push fit connectors into my charge pipes NTP fitting for boost reference.
xargentum
BMW E93 335i
I have an E93, and I have done this kind of setup, cooling is very good. No problem with Walbro 535 ✌️
Reactions: Torgus and BryaN54
3,593
Nice work. I'd suggest a fuel-safe locking compound (I believe loctitte blue 242 is fuel tolerant but check) on those nuts.
BryaN54
9
Used this stuff to seal my bed plate. Works wonders
Yeah, it look like a good match for my application. I was looking into other sealents too but since I only needed a little bit and anaerobic sealent has a crazy long shelf life I picked that one since if I ever needed to use it again it wouldn't be dried up on me.
