What is everyone doing to relocate the brake booster line? Are you just using softlines or is there an aftermarket hose for this job? I installed a boost box and have removed the factory intake so I have no need for that line or the vacuum barbs.
Make sure whatever hose you use it it will stand up to vacuum.
The Aeromotive -6 (3/8") is rated to 28 in.-Hg (if you have that much vacuum, you've got other issues).
PS. IF you damage the 90* fitting going into the HPFP, I have extras. I had to buy a 10 pack.
It was just some vacuum line i had laying around at work, i think it's 3/8" but dont hold me to that. I would take the fitting off and take it to a hardware store for size reference.What kind of hosing?
This is the last bracket revision MMP did for relocated inlets.SONO, what bracket are you using on your power steering reservoir?
I've got the EOS manifold so I have five barbs from 1/8 to 1/4
I'm not even sure which line that is exactly, connects to the throttle body or something right? When I get under there I'll check it out. I have an RB pcv kit that uses a barb instead of the normal position so I'm not sure what goes where yet as i haven't investigated it. Once my subframe is back in ill start messing with the other engine stuff, don't trust this engine brace.Ah yes. Well, that'll remove most of the need for a vacuum block, since you can just use those barbs. The fuel tank vent is a weak link, and that brake boost line is a weak link. If you want my leftover vacuum cap, heater hose and hose clamps... I think it's all just laying in my garage. You're welcome to it if you're ever in Scottsdale/Avondale.
