Bmw 335is 1/4 mile DCT 11.0 at 137 stock clutch packs and XPH flash stage 3 performance launch street tires
Mvaccarelli01
121
73
Wanted to share my Timeslip on my first successful Track day when everything on the car finally came together!
2012 BMW 335is DCT STOCK CLUTCH PACKS
Car has not been on a dyno
Getting drag radials on 17s soon low 10s possible?
Tried to go for 10s and up my launch slightly on last pass and spun launch. could of up boost a pound and stayed with the 2.1 sixty but didn't have time.
Feel like this is one of fastest passes with street tires. Think I could of easily had a 10 second pass. let me know what you think
DATALOG- https://datazap.me/u/mvaccarelli/log-1601325568?log=0&data=3-24
Picture of slip and of car is attached..
Instagram VACC_N54
youtube- https://www.youtube.com/channel/UCNT32eKs5sEWtHNDYxUgWeQ?view_as=subscriber
going to be uploading videos of dyno and going back to track day with radials for my 10s. subscribe if interested and want to see!
Turbo/tune
6266 doc race kit GFB Controller tuned by wedge
XHP flash stage 3/Performance launch used (traction all the way off) not standard launch control
Load by gear MHD option checked. 1st gear was limited to 8psi
Fuel
full E85
BMP PI with AIC 6
Stage 3 pump/hobb switch
Bolt ons
2 Step colder plug NGK
PR Coils
Evolution Raceworks charge pipe/w synapse BOV
7.5 inch VRSF Race intercooler
Catch can
secondary cats deleted
Suspension/Tires
STA XTA coilovers
wheels Forged apex arc 8
Tires Michelin pilot sport 4s
Front: 18x9 ET31 with 245/40-18 tires
Rear: 18x10" ET33 with 275/35-18 tires
Weight reduction
Rear seats were taken out
ALL maintenance done.
Your timing takes ages to recover after a shift because the actual is overshooting target and the boost target is doing wacky things so the tune has room for improvement.
I've managed to fix the boost ceiling issue on DCT cars so you shouldn't have to use boost scaling once MHD fixes it at their end.
Mvaccarelli01
121
73
yeah 3rd gear timing took awhile to recover, sometimes that happens randomly. Overboosting slightly after gear changes seems to happen often
