Mid 10s 1/4 mile on N54 DCT! xHP and MHD this platform is not dead. Please read
Mvaccarelli01
121
73
XHP performance launch on 18s r888rs wow!!
I want to add I did this on 18 inch tire not even a drag slick with a stiff ass b8 rear shocks, with zero boost off the line, and minimal weight reduction, on stock motor and stock clutches on my very first few passes!! I mean what the limits?
if I actually try to be serious and get a drag slick, proper line lock kit, a little more weight reduction. I mean low 10s could I even say 9 are possible. The mhp is there my 02 burned up half way down the track stuck afrs I will be able trap near 140.
XHP performance launch is great and with the new flash they definitely made this transmission possible to work with. But there is still no way to build boost off the line with traction control completely off. If MHD and xHP can get together. We need traction control completely turned off and be able to hold rpm and build some boost antilag these cars can be in pushing 10 seconds flat very easily. With a 1.6 sixty foot I am there dipping into the 9s
can someone please tag xHP, MHD. This platform is not dead. Let’s accomplish some records everyone
Mvaccarelli01
121
73
Ok, that explains the trap speed.
How much whp ?
How hard are you pushing the 6266 ?
I don’t know the whp never did a dyno
Not pushing hard at all that was 28.5PSI only 60 duty. I can turn it up more just pushing limits on stock motor but it will take a few more psi should be able to trap 140ish
Mvaccarelli01
121
73
Hey Mike, what was your launch method?
Hey bro, I did XHP performance launch, so traction completely turned off, and smash the gas, RPM was set to start slipping the clutch around 3300.
Also with MHD I set Load by gear on first gear with load option of 130 I think. This made it where it only gave me around 8-10 pounds of boost in 1st gear.
Mvaccarelli01
121
73
Here is the video of cockpit draggy on the 1/4 pass!! (dragy time was actually slightly slower then the slip)
I also have a separate video talking about the run and a few more videos of the pass on my channel check it out
How much whp ?
Great news!
Really amazing results,
What are your mods ?
PI?
NoGuru
1,213
Just North of Detroit
BMW 335is
Nice, I have a half mile race this coming weekend so I will try and post some results, if I get any :)
SlowE93
1,829
Just a plane ticket away !
E93
Nice....this should be close to 750whp on a 6266...great run and not taking anything from you, but the E9x platform just sucks for 1/4 mile.
Other cars with similar weight and 700+ WHP get down the track even quicker.
Once again, congrats and not taking anything away from you, just this platform.
Just watched the video again. Great video, you could tell the adrenaline and anxiety you were feeling. Nice rush ! Good Job !
  • Dislike
Reactions: 335is02 and JMVELA
Mvaccarelli01
121
73
Yes these cars suck from a 60 foot, which is why they aren’t the best from a quarter mile, the trap speed is there for a low 10 high 9 second run. Just doing the best I can with these cars for fun. Definitely agree there are better platforms for drag racing!
Mvaccarelli01
121
73
I finished with a best of 152.7 mph but every single run I went into limp mode. I would have been around 160ish if not for that.
There is a good chance it is related to the DCT but I will be investigating more to see what is causing it.
What codes was it throwing??
Reactions: Salo
