Who has E93 ?
LuiG
E93 335i
Reactions: Zhelyazkov
hellokitty
73
32
2012 335iS DCT E93
Installed a 50Ah AGM battery from the i3/i8. OEM is 60 lbs, this one is 30 lbs. Used BimmerGeeks protool to register it. She fires right up. The original battery is a fat pig. Every lb counts on a E93 lol
matreyia
1,780
711
335i e93
No electrical problems or faults with lower power battery?
matreyia
1,780
711
335i e93
2009 e93 335i N54
SUSPENSION
Entire suspension replaced with genuine M3 parts
All bushings replaced with genuine M3 parts
Koni Yellows set on firm
Eibach black springs (1 inch lower)
Dinan adjustable toe links rear
ECS Tuning rear trailing arm set
M3 front and rear swaybars
M3 strut tower brace upgrade
WHEEL AND TIRE
313 Genuine BMW 18” wheels
Michelin all season PS3 tires
front 10mm spacer
rear 15mm spacer
DRIVETRAIN
Propulsive Dynamics Transmission
xHP flash stage 3
Bmw aluminum guibo upgrade
M Factory LSD
Rogue Engineering Trans mounts
Setrab ATF cooler with two fans
ENGINE
PSP Dual cone intake
PR Ignition Coil upgrade
NGK 1 step colder plugs
VRSF DP
ER charge pipe
2 inch Inlets
1.75 outlet aluminum PSP
Revshift Motor Mount passenger side
PCV RB Delete kit
MM OCC
BMS OCC
Tial BOV
Sprint Booster v3
N20 tmap
FUEL
PR Stage 3 LPFP
PM4 Torquebyte LPFP Controller
BMP Port Injection
AIC 6 Controller
Motive Flex Fuel Kit
EXTERIOR
M Sport Aero kit
M3 side skirts
INTERIOR
BMW PERFORMANCE Electronic Steering Wheel
Walnut shifter upgrade
Mustang Dyno: 418 whp.
Dynojet: 490 whp.
hellokitty
73
32
2012 335iS DCT E93
I’ll have to run a diagnostic to check for codes but everything has been fine so far. I also keep the car on a CTEK charger when not in use so the battery is always full when I take it out. I usually only do this over the weekend since the 335is is my daily and my F80 M3 is the weekend car. By Monday, I have a topped off battery with no issues during the week.
hellokitty
73
32
2012 335iS DCT E93
Happy to report no codes have been triggered. A few things to keep in mind:
- don’t leave k+dcan cable plugged in when parked as it draws power even when the car is off.
- disconnect cig lighter usb charger when not in use
- leave the car locked when parked even if it’s parked in a garage to maintain battery charge.
