BMW F30 Rear M Sport Brakes on E9x
FPK
Arad, Romania
E93 335i N54 DCT
Hi! I searched the whole forum to see if anyone has had this fitted to their car. I found only old topics, a few years old. In the meantime, I think and hope that new ways have been found to adapt the rear caliper to the E9x.
I have an E93 335i, I put the calipers from the M235i on the front, they were plug&play, simple. But on the rear I've heard it differs a bit, and I want to put them on the rear as well because aesthetically it doesn't look ok as it is and at the power I'm currently developing, I need some stronger brakes.
Or do you know of any other rear calipers that I can adapt more easily? Thanks!
vonbimmer
Grand Junction, CO
2007 BMW 335i
I am in the midst of installing the set front and rear on my E 92 335i.
I don’t think too many people are doing the eccentric bushing anymore on the rear, I bought adapter plates from seems legit garage…
The Front is just an adapter plate, however, on the rear, you have to either use a 135I hub, or an E9x M3 knuckle — which Will White didn’t the stand by 7 mm I believe.
However, once you do that, it’s just simple bolt on… from what I read people are opting to do the m3 knuckles because you’re adding less weight and it’s cheaper.
Here’s a link to the parts https://www.seemslegitgarage.com/e8x-e9x
