Stock Parts and Spare Parts!
I will be updating this thread as I take photos, this will be my official, stuff left over thread.
Please PM me if you are interested or want to see more pictures.
All parts are off my Jet Black 2009 E93 335i Non-M Sport with 56-57k miles when removed. Other parts may be brand new as they did not fit or were not used. Many of the engine parts were removed when upgrading to single turbo, everything was functional at the time of removal and I have no reason to believe otherwise.
Interior:
Clek Oobr Full Back Booster Seat, Drift barely used - $200
Exterior:
Undertray
Fender Liners
OEM Angel Eye Bulbs
Air duct/snorkel
Stock Oil Cooler Duct
Stock Brake Ducts
Trunk Latch
HPB(High Performance Bulbs White LED Reverse Bulbs
Engine:
Radiator
Downpipes
FMIC
Intake Manifold
Stock Chargepipe Sensor
Airbox
Turbo outlet/hotside chargepipe
Waterpipe
Lower Chargepipe
Diverter Valves
Oil Filter Housing Cap and Oil Valve
Coolant Thermostat
Heater Core Return Line (Automatic)
DEI Line and Hose Heat Shroud
5' 1/4" ID high temp silicone vac hose
6 Bolt DCT Flywheel
Electronics:
Hifi Amp
SWS-8X 4 Ohm - Brand New
Samsung Gear 360 - $70 - New
Suspension/Drivetrain/Handling:
Stock 335i Brake Calipers F&R
Stock Rear Diff Mounts
Stock Motor Mounts
Rear F30 M Performance BBK Dust Shields - New
Other:
Miscellaneous Parts
Front Bumper:
sold
If you are upgrading your oil cooler or planning on putting a trans cooler in your driver side fender well or wanting to delete your fog lights, this is what you want:
sold
Heated Sport Steering wheel with clockspring, trim and multifunction buttons. The buttons may or may not work, everything else is in great shape.
20171014_135634.jpg 20171014_135648.jpg 20171014_135658.jpg 20171014_135708.jpg
sold
Custom cooler for Trans fluid or Engine oil. $375 without fan or thermoswitch
Mishimoto Large Dual Pass Bar and Plate cooler with custom custom bracketry to mount in grill area.
SOLD
Also have a 5.2" Spal pusher fan and a Derale thermoswitch kit:
Compared to Setrab Series 6 16 row:
Centric/Stoptech slotted rotors, front and rear - SOLD
sold
Combox Retrofit comes with:
61136913644COVERING CAP1$0.00$12.97$12.97
61136913626UNIV SOCKET HSNG 261$0.00$0.92$0.92
61131393726CONTACT20$0.00$0.96$19.20
61130006664PIN CONTACT20$0.00$1.45$29.00
[TBODY] [/TBODY]
Kufatec 37758 54 Pin Connectors x2: 24.05
MOST Terminator: $21.59
1 x Coax Type: RG174; Length: 15.24cm; Connector A: Fakra B Straight Plug; Connector B: Fakra G Straight Jack = $4.6
1 x Fakra Jack double "B"RA to TWO Fakra plug "Z"straight waterb = $10.68
BN2000 Combox Build Date 09.01.2015 $55
Retrofit harness made for cars with MULF2 + TCU
sold
Non- M Sport fender liners, driver side cut for PPK grill vent. I can include the PPK grill
