Single Turbo & 91 Octane - How much boost?
ShadyOrb
I just finished my single turbo conversion a few weeks ago, and I want to turn up the boost.
Currently with 14psi springs I get ~11psi w/ JB4.
Map2 is 17psi and I'm not sure if that is safe as I only have 91oct available.
- What is a safe level of boost on 91 octane?
- Also, for JB4 Map6 can I just set the boost I want under User Adjustment Settings and rip it?
Here is a log from the other night
https://datazap.me/u/shadyorb/n54-6266bb-2nd-gear-map-1?log=0&data=1-4
Reactions: Siimaa
Kaane
31
15
2008 535i
You could run 20 psi or 10 psi, it all depends. How much timing, how efficient the turbo is, how good the intercooler setup, what is the DA, ambient temperature. Way too many variables.
Work with a good tuner and they will extract safe power.
Reactions: ShadyOrb and wheela
DaddyBoost
17 psi no more than 7* of timing.
20psi, no more than 5-5.5* of timing
22 psi no more than 4* of timing.
All in all, do not exceed 11.6 afr as you would rather cool the block and run a bit richer
Reactions: ShadyOrb
please see this page
and see the reply,
also ,this means good condition and setup
1st: there is no log
2nd: you are quoting Shiv who is known to lie to sell his products. Shiv got ran out of this community before he started fleecing other car communities with his open flash product.
3rd: I have never seen it repeated
4th: The claim is they only used an inline walbro and the stock fuel pump. Stock injectors, stock HPFP, stock HP rail, no PI. 100% stock block.
5th: Shiv states, "There is plenty more power to be hand on 91oct" and then says " this 600+whp result is something that I'm not entirely comfortable with. Sure it can do this on a steady state 4th gear WOT pull on a cool evening. But environment conditions (and fuel quality) can vary day to day, month to month, etc,. This is the reason I would still recommend running 19psi on 91oct."
Maybe I am wrong and you can make it. Is it safe? Would you want to daily it that way? Let me just say I am VERY skeptical of 600whp on 91. Even on 93 with 10% Ethanol.
Reactions: The Banshee
Siimaa
Thank you for the link!
yuli8466
99
23
thank you for your detailed reply
yes , you are right ,that may be some "marketing skill" or " promotion information" , but I think with it can run 91oct . because when I was 19T twins ,I run 21psi 5degree with stock DI and very little Port injection with PUMP GAS, the block is stock, and piston is 9.5. If he run 6466 which is a lot bigger than my twins. I think even his piston is stock ,it is possible to run 21psi \6466\ pumpgas. and the power , maybe above 550whp and a little lower than 600whp. but it should be near.
now I run E30 and 25psi everyday ,So I can't test single turbo pump gas 21psi.
DaddyBoost
He will be close to hpfp limit at around 570whp, so unless there is helix, that will be the limitation.
