Single turbo 100 octane
yuli8466
99
23
I made 670 whp with straight 100 oct, with only a stage 1 or 2 pump on my 6266.
Hello , you said: straight 100 oct, do you mean: stock DI system , without PI/METH/shotgun ?
thank you
I am very interesting at this kind setup: stock fuel system race gas single turbo. , only LPFP upgrade
Payam@BMS
412
265
34
Hey Payam, how does this stack up against E85 ? From a safety perspective. E85 is cooler cylinder temps correct ? Pros and cons ??
E85 is like 10 times cheaper so that's the end of that LOL. Ms109 is good, but I think e85 is honestly the best.
The Banshee
175
104
Lehigh Valley PA
2008 335xi coupe 6466 MT
I did 593whp on Ms109 in 2014, stage 1 LPFP nothing else. Still had more to go.
Can you give us an idea of boost and timing on that run? Can you be more specific on “still had more to go”? Sorry for all questions but I am having a hard time finding good info when it comes to race gas.
Jan 31, 2017
404
852
www.hydraperformance.com
2010 135i 6MT
@The Banshee , FWIW the HPFP will crash without auxiliary fueling if you go much above 10 degrees of timing when running >600whp. Reason being that the increased cylinder pressures make life a lot more difficult for the (direct) injectors, so rail pressure goes to crap. I've seen this behavior on 3 different cars already, and validated my theory with an A-B-A test.
Jake@MHD
Nov 7, 2016
1,615
2,083
Philly
Tolino's Valero Station
100 S. First Street
Bangor, PA 18091
It’s Sunoco 100. You just need to join their fuel club to use the pump. I think it may have gone up in price slightly since I posted but still is the cheapest in my area by far.
Is this the one across from the Airport?
Jake@MHD
Nov 7, 2016
1,615
2,083
Philly
No this one is different located north of the 22 and 33 interchange. If you are coming from philly the one by the airport is much closer.
Ahh cool, didn't know there were two race gas pumps in such a close area. If you're ever going to maple grove or ATCO, etc, let me know :)
yuli8466
99
23
Hello ,based on his url link , I find the log the dyno chart. I am also doing this setup (race gas, only lpfp)
you can see :
24psi, 8 degree timing, IAT is not on the log,
HPFP flows like maxed out, but trims still low, so the hpfp is realy maxed out ?
6465 0.84 ar , maybe equal to 6266 gen2 cea 1.0AR.
So I think 600WHP (STD) is reasonable of the limition
VM Top mount twin scroll kit
Comp 6465 .84AR 3" Catless downpipe Tial Blow off valve
VRSF 7" intercooler and charge pipe
JB4 G5 With bummerboost Flash
255 Inline pump23-4 psi on Ms109
90 degree weather
593 wheel horsepower and 540 lb-ft of torque at the wheels on a Dynojet in STD correction. (STD:1.05)
Reactions: Payam@BMS
The Banshee
175
104
Lehigh Valley PA
Will do and if you are attending any Pocono events , Cars and Coffee, or if you are in the Lehigh Valley for that matter let me know. Would like to chat with you and personally thank you for all you have done for the N54.
Reactions: Hydra Performance
