Possible boost leak or just being daft ?
Subwoofer
267
48
Hello all, Running stage 2 + MHD with the Evolve DP + Intercooler.
Looks like the boost isnt hitting the target towards the end, do you think my wastegates are causing havoc ? Recently they have been making a very big rattle....
Click me for the datalog
Let me know, everything else looks fine.
Slowagon54
207
96
Turn it up. No timing corrections on the posted log. Flash the next Map with more octane and run a log. Shell V Power is a good choice.
Slowagon54
207
96
Good thing is, there are no correction with added timing. Which is very good. Strange thing is, the boost is off somehow. How old are the turbos? Is there an aftermarket bov? If yes, which spring are you using?
ajm8127
69
136
PA - US
2007 E90 335i
In the first log you are adding 15.5% with PID until 5743 RPM then it drops to the same as "WGDC Base Value". As soon as this happens your actual boost dips below target by about 3 psi. In the second log your "WGDC Base Value" and "WGDC After PID" are the same value and boost again is around 3 psi short of target.
I am still rocking an AccessPort from like 2013 and don't have MHD, but that wouldn't be normal on a log from my car.
Reactions: ShocknAwe
1,686
Interesting that your duty cycle doesn't hit hard up front to spool up the turbos. Can you do another log with bank1 and bank 2 WGDC. But you're at like 75% either way. For example: mine ran at lower duty cycle (40?) to spool to the same boost target when my car was FBO.
Reactions: ajm8127
Subwoofer
267
48
Hello, the turbos are still stock from 2007 with 58000 miles on the clock currently. No blow off valve either.
Well that’s what I’m worried about because it does seem odd, but could also be because of the wastegate rattle fix...
I have the wastegate rattle fix on 5% (lowest possible value) because at anything above it’s obnoxious. The vacuum test was done on wastegates and they don’t seal at all... so maybe that ?
WGDC looks very high to me but only as revs climb so could be a boost leak or maybe just old turbos.
Have you done a visual around the charge pipework looking for blow-by leaks?
Subwoofer
267
48
But could that be due to the fact I have wastegate rattle fully on ?
Doesn’t seem to be any blow by
ajm8127
69
136
PA - US
2007 E90 335i
Just turn off the rattle fix to see if there is any difference. It shouldn't be necessary at all.
I would be concerned why PID all of a sudden goes to 0. As @ShocknAwe noted there is no spool mode in the second log. It's like PID gives up.
So you applied 5.9 in Hg vacuum to the actuators and the waste gates were not sealing? On both turbos?
Subwoofer
267
48
The rattle reduction slider just changes behaviour when off boost I think. When on boost it won't make a difference.
Well that’s what I suspected... hmm
It was taken into BMW (was trying to get a warranty repair for turbo) the guy said that the waste gates aren’t sealing properly/working. I was planning on doing a 17T turbo
Do you have the proper Mondial BMW warranty? They should replace turbos with that one if you are forceful enough. I had both mine replaced at 50k miles with only minor rattle. Wastegates not sealing will cause what you're seeing in logs.
New turbos can still rattle a little though, just luck of the draw I think.
RSL
503
When PID stops and it just runs on base DC, there should be a 3100 code and probably at least one other code that caused the disable. The cause could have nothing to do with the turbos at all, vanos and others will disable boost control.
Once 3100 is set, need to restart the car to get control working again, which is why there is none on the second log.
If the second code is related to boost, like 30FF, could just be a tune issue, but a hardware problem (boost leak, etc) is always a possibility.
Subwoofer
267
48
So I checked DTC codes and I had a 30FF (shadow) do we think that’s because my wastegates are buggered ?
RSL
503
As far as 30FF, actual isn't close enough to target for too long and the DME stops trying. Why actual isn't close enough to target can be because target is just too high to reach for the WGDC, boost is low for the WGDC or some combo of both.
If it's low boost for WGDC, could be any number of causes: low atmospheric pressure (yours isn't), boost leak, WGs, solenoids, vacuum leak to the solenoids/WGs, bad solenoids, etc.
There's only so much stock turbos can do over 5500-6000rpm even when everything is working perfectly, but WGDC seems like it might be high regardless. I'd find other logs to compare with to verify, I dont keep up with them much.
I'd personally check for boost leaks and any vacuum leaks first and foremost, but WGs are certainly a possibility. It's just not something you can diagnose over the internet though, there are many potentials and you'll have to start ruling them out. Not sure how much more you'd get out of them up top either way, but never hurts to make sure there are no leaks.
