PCV Setp Issues
@juan35i
40
Bakersfield, CA
2010 BMW 135i
VTT Cast aluminum valve cover
VTT dual catch cans
Vacuum relief valve
Blocked head ports
Currently running this catch can setup but having these codes. What am I missing? VTT sent me this diagram so I followed with it. I have not installed a breather cap. Is that the issue? Thanks in advance
675
I think the Code 2D2E is the source of your issues.
I don´t know where Vacuum is connected in that setup but your throttle valve control is not working as expected because of a vacuum leak somewhere in that area.
Reformatt
81
41
Houston
2010 335i E92
Might want to add a check valve before your VTA filter. I also had to adjust the vacuum relief spring..I snipped a bit of mine..I noticed excessive vacuum when taking the oil cap off…Was pulling on my palm like a new gf 🤣😮. Before fine tuning the vacuum/crankcase pressure I was constantly replacing valve cover gaskets path of least resistance I assume..
There are many configurations to achieve the desired results. Kinda dirty but that is how mine is set up.
After your sorted I would reset some adaptations an hopefully some of those codes will sort themselves out ;) 🤞🏻
