Oil dipstick retrofit
3,574
Someone needs to do an exchange program. I'm curious to know if anyone has installed a dipstick on their N54? I saw bimmerworld had an S65 retrofit kit. I've done some Google searching, but mostly found rants on other forum threads.
Thanks,
dyezak
1,768
1,518
Plano TX
335is
Hrmm...wouldn't be difficult to retrofit someone with a single conversion. Just use the rear turbo oil return opening in the block to fab up an oil dipstick using one of the flexi-sticks.
3,574
Nice ... do we know anyone that's gone down this path?
Cheezy
611
225
Toledo Ohio
I'm fairly sure I saw about a year ago where one of the vendors put one on the oil pan of their half mile car .I don't remember if it was ade, motiv, or vtt tho. For some reason I think it was one of them.
Reactions: fmorelli
3,574
Well for one, I don't have iDrive: one has to do the signal stalk antics to see what's going on. Second, I'd rather see fluid on a stick than rely on the level sensor. Third, I'm in love with my Mightyvac for oil changes - and especially with my E89 Z4 which is very low to the ground, a complete pain in the ass to change oil at the house garage.
Reactions: seb.apprenti
The Convert
1,487
1,049
Don't suck your oil out of the dipstick to change the oil. You leave all the debris and contaminates that accumulate in the oil and sink to the bottom. I had an A4 motor get starved of oil and require replacement because the stupid f*cking dealership did this for their oil changes.
pdxbimmertech
21
9
Portland, OR
2008 E92 335i 6 spd
When you drain the oil from the drain plug it does not get "all" the oil and debris etc out. When you pull an oil pan on a N5X engine there is always some oil left in the pan along with anything else that has collected and settled/stuck to the surface of the pan.
Also, depending on what engine it was in your A4, the 4 cylinder VAG turbo engines are well known to get gummed up in their oil pickups and ruin engines due to oil starvation on both the 1.8t and 2.0t engines. Just what I have seen FWIW.
I have always thought it would be a great idea for a company to develop a retrofit for an actual dipstick.
Kommodore
Cactus Farm
With the M3 cluster sport display I just have oil level as my default screen. Shows oil level as soon as the car is able to read it. That being said I would still like a dip stick either way.
