Need toe arm suggestions
veer90
1,000
774
West Nyack, NY
e90 335i 6MT
Can anyone suggest me some toe arms for a high hp N54? I daily it at 650+ wtq and it makes 755 wtq on kill.
I been through 2 sets of rogue engineering toe arms with the spherical end bearings and grease fittings. This new set of bearings already have play in them after a few thousand miles and I make sure to grease them every few weeks.
Should I install a toe arm w rubber end bushings like Manzo?
In the rear I have m3 control arms, ECS billet trailing arm, and RE toe arms. If rubber is fine for the power I'll use it, tired of developing play and having to replace arms then needing alignment.
SJ_1989
368
299
Illinoisssss
2008 E90 335i
I've heard good things about SPL but I haven't used them so can't really comment other than this is what I'll be using in the future.
1,689
Honestly, I think a high quality rubber sealed bearing (not spherical) is your best bet. I've been through 2 sets of spherical toes and switched, won't be putting any more sphericals on the car.
bantam
128
105
2009 335i
Supposedly Barry @3dm was working on something for this, but he has since turned into a ghost. Anyone heard from him on his ball joint toe arms?
gmagnus7
174
73
135i N54
or just put poly bushings in the toe arm if you dont want spherical or sealed rubber
Slonik
Moscow Region, Zhukovskiy
slon-workshop.com
E46 M3
and anodized in black
cnc machined from aircraft aluminum. ready for long time and everyday usage, silent bearings, (similar to oem bearings), which you can change per 20-30$ per piece.
we've made them with corrected custom length for our track prepared lowered e82 cars (non M suspension setup), to go with 2-2.5 degrees negative camber.
we can made any length, so for 1m/m3 suspension also.
1,689
Very similar to what I have for toe arms, can definitely say this is the way to go.
bantam
128
105
2009 335i
So Barry kind of left us hanging with updates, but his website now lists stock arms with pressed in bearings for sale. Alternatively, according to a thread in the N54 section of bummerboost, you can buy an OEM style lemforder bearing that is a direct fit to press into your stock arms. If the concern is the flexure of the arm, then you are basically stuck doing a billet arm with bearings, none of the aftermarket style appear to incorporate proper bearings
