N54 Single Turbo 6266 Dyno at 24psi
Terry@BMS
Jan 23, 2017
463
375
Helped a local customer at the dyno the other day and thought some might find the results interesting.
The car is a 2008 335, ACF top mount kit running a 6266 G2, China intake manifold w/ port injection (we'll be stocking these soon), JB4 with integrated PI control, MHD BEF (E85_TS_PI), 4bar TMAP sensor.
First thing we did was update to the v13.4 single turbo JB4 firmware which has a new map guide for 4bar customers. The new maps are as follows:
Quote:
Map 0: Disables JB4. Required for any flashing or OBDII diagnostics.
Map 1: Wastegate spring, throttle closure over 17psi (also safety map)
Map 2: 20psi
Map 3: 24psi
Map 4: 28psi
Map 5: 32psi
Map 6: User definable map
Map 7: 36psi
Map 8: Progressive WMI map with integrated safety adjustable from 17psi to 36psi
[TBODY] [/TBODY]
Tuning is running all off the shelf settings, except for some reason he had DWP (spool mode) set to 60. Meaning WGDC stays at 100% until boost is at 60% of boost target.
Anyway did a run on the new map3 and everything looked good but spool was lazier than I expected. Noticed DWP setting, changed to 75, and did another run. Response was back to more reasonable levels. He should probably take it up to 80 or 85. Then we went to do some runs at 28psi and dove down the rabbit hole. First a loose hose blew off the throttle body that had to be repaired (with duct tape), then the car started sputtering at higher power levels and eventually threw a misfire cyl2. Rolled back power and everything was fine again. So next up for this car stronger coils and new plugs, I think. Interestingly at ~28psi sputtering it still did 700whp. Didn't have a chance to look in to the timing drops but like all single turbo cars, we run them with stock knock tables these days, so likely a little false knock there.
Overall though very happy with the power levels at 24psi. The car will be out at NFZ next week, hopefully misfire free!
hardparker
80
33
f25
Nice numbers! What's your ultimate boost target, and with what fuel?
Interesting that you'll be selling that Chinese PI manifold soon, too. Curious to see costs on that. Is it N54 only, or N55, too?
Nice numbers at 24 psi, would like to see what it could do when its misfire free
Terry@BMS
Jan 23, 2017
463
375
Owner is looking for 750whp @ 32psi, IIRC. On the manifold we'll have them for the N55 applications too. Price will be good, but can't share that until I see what our landed cost winds up being along with the minor modification we need to make to get the up to our standards.
  • Disagree
Reactions: Twinz
Payam@BMS
412
265
34
VM/ACF Top Mount PTE 6266
Phoenix Racing Intake Manifold W/ Port Injection
Phoenix Racing RACE Intercooler
Phoenix Racing Chargepipe Tial BOV
Fuel.it Stage 3 LPFP
BMS Jb4/PI Controller
BMS/MHD Full E85 ST BEF
Spec Stage 3+ Steel SMFW
dyezak
1,767
1,518
Plano TX
So is VM/ACF only offered through BMS now? Trying to figure out why nobody gets any response or hears anything from VM/ACF directly and the only people posting up are the BMS crew.
Terry@BMS
Jan 23, 2017
463
375
VM sold to ACF when Payam went to work for BMS. BMS does not sell turbos or turbo kits. ACF is an independent business that sells turbo kits. But, their main focus is on manufacturing. In fact they make a lot of parts for BMS and other companies. But they still sell the turbo kits direct as well.
suspenceful
10 Second Club
Aug 1, 2017
559
592
75
2015 M3, 2008 135i, 2009 335i
Nice! What does the ST_E85_TS_PI flash target for timing?
dyezak
1,767
1,518
Plano TX
About what you see in the log above. 4 degrees peak torque up to 7-8 degrees at high RPM.
That's impressive results for a moderate (and safe) amount of timing. Congrats! I'm betting there's more power that could be had tuning that ignition advance (at the risk of reliability).
