Maxx ecu standalone n54
Silentkiller335i
116
178
Just wanted to share 1 of my builds, its running a maxx ecu on port injection only, DI holes are plugged, maxx ecu controls every factory component like water pump, vanos,throttle body,e9x canbus, fuel pumps, and anything else you can think of or want, this car is more track oriented as its going for the 1/4 record held by ghasssan. Has 8.8 diff, dss axles, stock 6 speed manual, with x clutch twin disk.also features a 1200hp w2a intercooler that does extremely well. All fab work and wiring done by me, also not alone on this project as @willettrun had a big help with all my questions on wiring and he did all the configuration and setup on the maxx ecu along with the tuning. Car starts up , drives normal like any other 335i even with 2200cc injectors on e85. But the big difference is having full control of everything you want. Antilag, launch control, 1 post 02 sensor, boost by speed,rolling antilag the list goes on, this beats paying the crazy money for a syvecs unit and having all the same features for a fraction of the cost. This is the first n54 in the states running this, also is the test car. As we plan on making plug and play harnesses available.
houtan
635
318
135i N55 DCT; PS2
very cool and thanks for the information.
Did you go PI only because that’s your preference or is it a limitation of the ecu that it cannot control the DI side of things?
Reactions: RuskiRacer
SlowE93
1,654
Just a plane ticket away !
E93
Just wanted to share 1 of my builds, its running a maxx ecu on port injection only, DI holes are plugged, maxx ecu controls every factory component like water pump, vanos,throttle body,e9x canbus, fuel pumps, and anything else you can think of or want, this car is more track oriented as its going for the 1/4 record held by ghasssan. Has 8.8 diff, dss axles, stock 6 speed manual, with x clutch twin disk.also features a 1200hp w2a intercooler that does extremely well. All fab work and wiring done by me, also not alone on this project as @willettrun had a big help with all my questions on wiring and he did all the configuration and setup on the maxx ecu along with the tuning. Car starts up , drives normal like any other 335i even with 2200cc injectors on e85. But the big difference is having full control of everything you want. Antilag, launch control, 1 post 02 sensor, boost by speed,rolling antilag the list goes on, this beats paying the crazy money for a syvecs unit and having all the same features for a fraction of the cost. This is the first n54 in the states running this, also is the test car. As we plan on making plug and play harnesses available. View attachment 49289View attachment 49290
BadAss !
Its so simple and clean i love it!
Milan
413
241
jebi se
your mom
Post some dynos I want to see the torque curve. The DI is a pain in the ass but you got rid of basically the only good thing about this motor.
If you are going PI why not just use literally any other motor that’s infinitely better for a drag car?
Silentkiller335i
116
178
I will when we get to that point. Because im already doing that to my e90 . That will make 1700hp with a 2j and running a sequential transmission.
so my e92 is staying n54 so i can push the platform and break all the records
