Ad: M18 Performance Cast Aluminum Valve Cover
bahn
Nov 5, 2016
206
319
Iowa
Update- gasket is blowing out everywhere on Vc. Anyone else having that happen?
No such issues here, my VC gasket is not pushed out. Sounds like you over torqued it possibly. If this was a boost issue (unblocked PCV ports and a PCV issue) I would expect to see oil vapor being pushed out as well. Any pictures?
twinturbos
269
66
E92 335i MT
I might be selling mine if anyone is interested. 500 shipped. Comes with the bracket for stock coilpacks.
BOosted 335i
317
106
New Jersey
E90 BMW 335i
I think at minimum you should have a valve cover breather installed.also if your removing the valve cover also then why not just plug the ports also.just few extra steps.its better to do it then then removing everything the next go round.
m18performance
BMW 335XI
The cause of the gasket getting squished out is because over torque. When engine is hot aluminum will expand more over plastic. Make sure to use correct sequence and do not go past 5.2 FTLB
We torque 3.5FTlb on our Track car .
Seaneezy
130
34
e90 LCI 335i
The cause of the gasket getting squished out is because over torque. When engine is hot aluminum will expand more over plastic. Make sure to use correct sequence and do not go past 4.2 FTLB
Isn't the stock torque 7 ft/lbs on the OEM hardware? Luckily I haven't torqued down the bolts yet but you may want to update this on your instructions sheet.
Reactions: Idratherbesurfing
m18performance
BMW 335XI
Stock cover is plastic does not expand as much as aluminum. Sorry I made mistake with the post its 5.2ftlb same as n52 magnesium cover. We did update the instruction. We run less because our engine gets really hot after 20 laps never had a leak.
steve30
15
E36 M3, E90 335 ST
what is the thread on the catch can ports? I just tried to install my catch can lines which are using -10AN and they dont fit.
steve30
15
E36 M3, E90 335 ST
I had to mess around with it a little and my -10 went in.
interesting.. what exactly did you do? it looks like the threads on the valve cover are larger pitch. The -10AN fittings don't go in more than 1 turn and it binds right away. I don't want to force it in and cause any damage or galling..
m18performance
BMW 335XI
Pictures of your fitting threads ? They are 10an fits perfectly every time. It might be a challenge to get it going since the engine is in angle .
Seaneezy
130
34
e90 LCI 335i
They're intended for 10AN ORB fittings, haven't tried using a regular 10AN but my radium ORB banjo fittings worked well.
Reactions: m18performance
steve30
15
E36 M3, E90 335 ST
31290
I am using the -10AN and it won't thread in at all. Based on the photo above the threads do look different. Top is the catch can which the -10AN goes in no problem.
m18performance
BMW 335XI
Looks like your threads to fine to be 10an . Here is a picture near Radium 10an 7/8 -14 .
Your looks more like 16 threads per inch you sure its not 8an
Reactions: bahn
