HC Performance teases B series OBD flash
Two weeks ago a company called K8 Strasse announced something similar, but it seems that HCP is next to hit headlines on flashing the MG1 ecu found in some of the newer cars such as the F90 M5 and those with the modular B series motors(B58, B48, etc). But this time we also get a log printout of part of the process:
B48 MG1 tamper code aka warranty loss (will be removed)
This right here states that the car has been unlocked and flashed by OBD... Yes, shit it cracked :) #bosch #lmao #mg1#didnttakelong #bootmod3 #bm3#a2performance #b48 #hcp #worldsfirst#notyourordinarytuner
For a google translation:
DME, wrong record: variant monitoring
Test conditions met
Error currently available and already saved
Error would cause a warning lamp to light up
This is no event DTC. This ecu IS RESPONSIBLE for this error
I'm not sure exactly how this is done, but considering they have Bootmod3 tags, we can assume it is done or will be done using the BM3 software. Perhaps @PTF can chime in.
Reactions: PupkinRacing
cookiesowns
26
7
2010 535i ZHP6 + 2017 M2 6MT
From what I understand still requires a bench flash ( no drill, no take apart ECU ) but some sort of bench flash. Only dealer is somewhere in russia. HCP is working with another vendor for this.
There is a first flash which takes 8 hours. But they say its done over OBD and not on the bench. I'll dig for more info.
cookiesowns
26
7
According to the vendor that works with HCP, they mentioned it's bench flash first. Maybe OBD direct to DME? Bypassing ZGW and other things?
top-ecu
bmw 320li b48
We have devices that can read data from BMW B48 B58. But I don't know how to adjust the data.
