Finishing up ST Build
B@man335
09 335i xdrive, stage 2
Had a couple last things to clarify before I crank her up. I’m about to finish my ST build and maintenance on an xdrive e90.
After I finished rod bearings and oil pan gasket, I found conflicting info on rod bolt torque. There was a thread previously that highlighted we are supposed to torque to spec then 70+70 angle or 140 angle. I did the (earlier?) version in some manual of torque to spec then just 70. Will that be fine or do I have to rip everything back out again? If the latter, do I need all new pan bolts?
