Hi guys, i have an e92 n55 and i recently changed the oem outlet to the upgraded VRSF one. i swapped over the o-ring from the oem outlet to the VRSF outlet.
it seems to be very loose, i can freely turn it by hand without using any force, is this normal?
i dont know if it was this loose before i took the oem one off, however when i put the oem one back on, its also very loose.
im not able to drive the car at the moment as there are a few unrelated issues with it so i cant test to see if it will have a boost leak or not.
is it normal for the outlet to be be loose and able to easily move around by hand?
