Dynamic autowerks stg 4 log e85
Mikenazz
19
18
Here is my daw stage 4 log attached. Let me know what you guys think of the log and any issues?
Will get some drag times soon.
These turbos are doing great so far 1500km. They pushes a lot of air down low to high rpm.
Mods
6AT XHP stg3 - 335i e92
Dynamic autowerks stage 4
7.5 ic - Aliexpress special
full E85
Bl coil packs
Jb4 treb tuned 28psi
Fuel it stg 3
Bms pi
Full exh
  • St4 e85 _Map-6.xlsx
tisdrew
179
91
09 335i 6MT
WGDC is mostly in the 60s with a peak at 71. Seems like the turbos could have more in them and your IATs are still fairly low and timing isn't wild, more on the conservative side. Looks like the turbos have more sauce than stock pistons could probably handle. Good stuff!
Reactions: Mikenazz
RNM
175
166
Interested to see how you do at the drag strip with these turbos. What was your best et/trap speed on your previous setup?
gmagnus7
174
73
135i N54
For an arguably standard set of twins (god knows how many are offered now), the log looks pretty good even at redline. Not gonna lie, kind of surprised with how well the iats and wgdc look.
1,285
779
I provide this as a free service:
Additional information
FirmwareInterfaceEngineTMAP_VAvgIgnDWPMethTriggerModeFFMethSafeModeMethAddMethScaleMethPSIVINE85_SetupVFF_Offsetfuel_30fuel_35fuel_40fuel_45fuel_50fuel_55fuel_60fuel_65fuel_70
32/12//2JB4 Android A289E Series - N541.920.360380375997.9............NONE142505050505560656565
BoostSafetyPID GainAutoShiftRedFuel_OLFUA1st_limiter2nd_limiter3rd_limiterFUDN20_TMAP6CylModeLastSafetyduty_15duty_20duty_25duty_30duty_35duty_40duty_45duty_50duty_55duty_60duty_65duty_70
30256540014.22401_2_5_6_ON141505050454545455555606055
Mikenazz
19
18
IC is form aliexpress - works great it seems - although not as dense as the vrsf ones. Lighter because of this.
yuli8466
99
23
nothing special , locally we have many cars of E90 N54 auto runs like this with 16T/17/19T (made in taiwan , 1500-2000 usd) . the difference between them is PWM ( 16T higher or 19T lower).
HKD126
2009 335xi
I’m no expert, but isn’t your HPFP dipping very low in the upper revs?
ram00sa
in for the dyno, can you give a run for the poor people out there with no meth and e85 on the dyno, you might break a record with a turbo like that
Reactions: GreyNBlueE92
Glassreflectionzn54
98
36
N54 335i
Mike I really want to know how the turbos holding up! I had the stage 2 daw turbos and they were amazing! But I just ordered the stage 4 but not sure what to do. How are they? Msg me on Instagram: alex_glassreflections
