Has anyone successfully set up an N54 to run on port injection only? Not exactly sure what the pros/cons of such a set up would be but was curious if it’s possible or has been done.
Given the fueling limitations and issues of this platform I wouldn’t say thatNope, because this would be a terrible mod. It would be better to switch to a different engine(head) or completely different platform.
You are better using a S54 block if going with that route.Yes, it's called N52 with turbo
Motiv is running an N54 with the head machined to allow for N55 injectors. It's also running a motec since it can fire the N55 injectors.i thought motiv's track car was PI only.
This conversation is the exact same one had by hot roders and tuners all over back in the early 1990’s. This stupid fuel injection. Rip it off and put on a carburetor.
