Had issues with my old battery losing charge so I got a replacement AGM from PepBoys to replace it. I've done this before and it was fine. On the latest replacement, when going to register the new battery I realize I have no power whatsoever to the car. I insert the key fob and there are no lights on the dashboard, no pump priming sound or anything. I double-checked the connections on the battery and the 13mm up front and no dice. I looked online to see this issue mainly being related to a faulty B+ cable behind the fuse box, however it seemed that a correct diagnosis was by shaking the fuse box or wiggling the 12V cable behind the fuse box. I shook the box and wiggled the cable after removing the glove box and lower cover and I still had no power whatsoever.
Before I go about removing the fuse box to check the connection (I would have to tow the car at that point as I don't have the crimping expertise to be confident about replacing the cable), are there any other potential causes for this issue I can check first?
So far I have hooked a battery jumper to the engine bay leads and used a backup key fob to check if the current one was dead. I zip-tied the positive and negative battery terminal cables away from the battery to help installation, could I have bent those cables doing that?
Thanks!
Thanks!
