ADE 6870 335i hits 802 @ 30 psi
@M3RCLESS (Amit P.) provided us with some footage of his work in progress car. They are aiming for 40+ PSI and have yet to use the nitrous, the latest run came at 30psi:
Mod list:
MOTOR
Benson Sleeved block
Wiseco pistons
Carillo Rods
ARP ½ Inch Head Studs
Ported head
Ferrea Valvetrain
Shrick Cams
Modified PCV System with a baffled port in the block to release all PCP
DRIVETRAIN
Spec Twin Disc Clutch
Aluminum 1 piece Drive shaft
Drive shaft Shop 1000HP Axles
Ford 8.8 Inch Diff with Helical LSD
CAE Shifter with Reverse lockout
POWER ADDER
AD – Engineering Single turbo kit with Precision 6870 Gen 2 BB Turbo
NX – 125 Shot nitrous kit (DRY)
AD – Engineering 1000HP Stepped Intercooler
Fab Factory – Intake manifold with 750cc Injectors in the port installation
Precision racewerks LS coilset
ENGINE MANAGEMENT
Haltech PS 1000 in addition to the stock DME on a MHD Flash (Waiting for Syvecs)
SUSPENSION
Ground Control Full Race coilover setup with Camber Plates
Entire M3 conversion , every arm ,sway bar nut and bolt has been changed to M3
WHEELS
STREET
Apex Arc 8 with Mickey Thompson Street SS and continentals up front.
DRAG
WELD 15x10 and using 275/50/15 MICKEY THOMPSON
BRAKES
Stoptech Big Brake Kit front and Rear with Extended studs
ARP wheel studs​
Also special thanks to:
@AD-ENG
Horsepower Barn
Force Fed Engineering
@WedgePerformance
Fab Factory - @A4RingedONE8T
@m18performance
S&K Speed
Nice!! Graph?
Hey Payam... We have only done 4 revisions to dial in port injection on the Haltech and increase boost to 30 psi using BoostBOX and MHD Flash to control boost. Our goal was 800 whp and we hit that goal before running out of time. Currently on stock VANOS so we have a bit of work to do before we post up any graphs for public review. Hope all is well.
AD-ENG
122
140
Just a small correction... it doesn't have 1/2" head studs.
This car has lots more to get sorted, but looking very promising with lots of potential.
Reactions: LuiG
A4RingedONE8T
82
134
Sounds like it's doing some work! Spool is pretty responsive for the turbo and big back housing
-Shawn-
Payam@BMS
412
265
34
Sounds good Ken! Keep up the good work brother. Looking forward to more information once completed.
dyezak
1,767
1,518
Plano TX
335is
Just noticed you are on the dyno with your MT Street SS's. Those things are known to explode on the dyno and MT has explained the reason behind this. They've also said the tires aren't to be run at all after experiencing a full power dyno pull. This is MT SS8 technical bulletin. The reasoning behind this is because a dyno creates a concave contact patch inverting their tire rubber over the dyno rollers (slight reverse arc in the tire tread created by the radius of the dyno roller) causing extreme heating beyond what the tire was designed for. Anyone who owns a dyno should know this is a big no-no, and is a well known issue. If you've never seen a tire explosion on a dyno here you go.
