Abacus38 2007 e92 335i build
Abacus38
643
385
Tampa/Orlando, FL
2007 Ti Ag 335i
I haven't made a build thread so I guess now is the time lol. So I ordered a 6766 Jp kit but I'm still waiting on my 6766 and my wastegates so I went ahead and order a s257s-xe and turbosmart 40mm wastegates so my car can stop rolling coal like a diesel truck.
Parts ordered so far
PR Stage 2+ LPFP (http://www.precisionraceworks.com/)
S257sx-e supercore( www.thmotorsports.com)
2x turbosmart 40mm (http://www.sparktecmotorsports.com)
AD Engineering catch can kit( http://www.ad-eng.net/)
Jp Works 6766 turbo kit (http://jpworkz.com)
ACF Coolant and oil fittings (http://www.burgertuning.com/)
RB oil return fitting (www.rbturbo.com)
Doc race Turbo blanket( www.docrace.com )
Parts that need to be ordered
PR Stage 3+ LPFP
Syvecs
AD-Engineering Port Injection Kit or VTT Double Barrel. Havent decided yet
Coils( Want to go with PR but I heard their coils doesnt fit the JP so im leaning towars Bimmerlife)
ADV o2 sensors
Vanos Sensor
Spark plugs
Stainless wastegates lines
QuickJack 5175376 BL-5000SLX Car Lift
and whatever else im forgetting lol
Abacus38
643
385
Tampa/Orlando, FL
2007 Ti Ag 335i
I ordered an e tuned from motiv when the boost box first came out but i haven't used it yet. Going install the s257sx-e use the e tune from Motiv and just stick with that until i get my tax return. Once i get my tax return i'll order the syvecs. I'll be looking to buy a spare motor in Jan that I can build on the side....I mean i wont be building it ill send it somewhere else lol. I know honda motors but I'm not messing with this one.
4,348
Yeah, I'd LOVE to build this engine from home... I just don't know enough to feel confident putting thousands of dollars worth of forged internals in and fucking it off.
dyezak
1,767
1,518
Plano TX
335is
ETS would be good, but I think the only person at ETS that tunes Syvecs is Eric and I don't even want to know what he charges per hour for labor (assuming he's not out setting new records at some event). Motiv will work, but there are other Syvecs tuners in the states...one is about 10mi from my house.
Abacus38
643
385
Tampa/Orlando, FL
2007 Ti Ag 335i
Exactly. Building Honda's is like Legos. Very hard to fuck it up but these motors I don't want to touch. I'll leave it to the pros.
Abacus38
643
385
Tampa/Orlando, FL
2007 Ti Ag 335i
I see Evo performance is also a syvecs dealer/tuner too which is great because they've tuned a bunch of n54/55s
dyezak
1,767
1,518
Plano TX
335is
There are a few out there. If you have someone close to you that can do some dyno tuning that would be the best. I'd expect the PNP kit to get you driving around. You'll probably want a couple hours of remote tuning ($3-400) followed by about 3-4hr of dyno tuning (~$1000 ish).
Jake@MHD
Nov 7, 2016
1,615
2,083
Philly
What's the complexity preventing their compatibility?
I'm sure they could add it in, but right now it's only: "• Closed loop Dual Lambda Control using OEM lambdas"
We had to change a lot in the DME to get them to run. Everything is different, from pressure compensation, to ip gain, to the AFR conversion curve, etc.
dyezak
1,767
1,518
Plano TX
335is
The N54 PNP is based on the S6+, and the N54 PNP tune is set up for the factory sensors, but the S6+ will support:
2 x Lambda Inputs Including:
- 1 x NTK, Bosch LSU4.2/4.9 or Denso AF Lambda Circuit
- 1 x Bosch LSU4.2/4.9 or Denso AF Lambda Circuit
I'm on a conference call so I can't dig into what the ADV sensor is and if it is one of those "types".
Abacus38
643
385
Tampa/Orlando, FL
2007 Ti Ag 335i
Ordered the turbine housing for the s257s-xe from boostlab down here in tampa. Went with the divided t4 housing 1.22 ar. I'm also having the housing machine to the standard 3 in vband outlet ceramic coated black. I should have in 2 weeks. Going to ordered the single barrel shotgun 2 weeks when I get my commission check. The goal is 550-600whp on e85.
Abacus38
643
385
Tampa/Orlando, FL
2007 Ti Ag 335i
Went ahead order Omar's intake filter and exhaust manifold studs, gaskets, and nuts. Also ordered a Plug N Play mac sensor. Waiting for Chris to get back in touch with me about the adv sensors
