4N Performance Twin Scroll short runner bottom mount ST kit
Hey folks! Thanks for the info on the 02 sensors. I will see how it works and probably incorporate a spacer to remove the 02 from the heat. just know that this is a test manifold that was thrown together very quickly. The majority of the stuff you see there I had laying around my garage. I come from the diesel world of Performance. Always wanted to jump into building a single kit for the n54. This kit is made entirely of mild steel sch40 Weld Els. This will not be the final construction material. I will be using backpurged 321 stainless on the kits for sale. Also the downpipe pictured is galvanized it was tricky to weld to the stainless v band adapter I used. If you have anymore questions feel free I will be testing this setup this weekend it is already installed in the test car. No modifications necessary! stock right side motor mount and bracket are still used.
Thanks for chiming in. I know its hard to predict with the holidays, any ballpark estimate for public availability of the kit? Have you considered fitment of the GTX turbos or non EFR BW?
4N Motorsport
62
87
California
4nmotorsport.com
1947 Chevrolet 4bt 70psi 890tq
So far first drive was today. Turned out way better than I expected. will post logs and Dyno numbers soon. Its an absolute beast only running on wastegate spring with jb4 st software map1 13psi. Full boost at 3900. I am Currently building jigs after the prototype has been tested fully. Assuming everything is going perfect I plan to start building these kits full time starting Jan 1st. I have considered fitting a Borg Warner turbo just haven’t gotten to it yet. I have a s362fmw that I run in my 4bt Chevy. 70 psi for over 3 years Still holding up lol. They are awesome turbos. I will bolt it up and get back to you guys on that. I have not attempted to fit a gtx series turbo yet that is something planned soon as well.
13psi at 3900? What gear is this in?
1,615
2,083
13psi at 3900rpm is pretty horrible. Also, one day of testing and claiming no o2 issues is also pretty horrible. You need a few months minimum.
Aaron
544
201
Colorado
Silver 2013 335is 6MT
Jesus man give the guys a break, this was their first day running the car.
He clearly said that was on wastegate spring only, no boost control and I doubt any spooling tricks with VVT either. He clearly said no O2 issues yet, but that he is going to add modifications to prevent this from being an issue in the future.
I still remember how shitty the 2010 Camaro was. Now a ZL1 embarrasses a 911 turbo, and is on the bumper of a 918 around a road course.
4N Motorsport
62
87
California
4nmotorsport.com
13psi 3900 is not horrible considering low timing and safety map. the turbo starts to light in the 2800-3,000 range. I am also running a 1.00 ar turbine housing. you guys sure love scrutinizing the shit outa this don’t you? Base 20psi tune starts tomorrow. I will slowly bump it up day by day And you’ll get some results by the weekend.
Adil
23
9
California
Im running the kit now on my car. we haven't even tuned it just wastegate at 13psi Pure evil tuning will be helping with this. Still got couple more things left to make it fast ha all you guys know I do nothing but racing with my car. check it out on my page @1freakyfast335i
