335is passenger motor mount
3,629
P/N: 22116793240
Anyone know what is special about it? Aside from the fact that BMW charges $600 for it?
dyezak
1,767
1,518
Plano TX
335is
It's a liquid filled mount that uses magnetized fluid. The mount is electromagnetic and the DME actually stiffens the mount as load increases (sort of like manga-ride shocks). That way at idle, and cruise, you have a very pliable rubber mount that gives great NVH but when you are really pushing the car you have an extremely rigid stiff mount that gives better performance.
@doublespaces can explain more I think
cloud9blue
255
190
09 E92 335i
I hope this is a joke... e9x doesn't have those fancy dynamic motor mounts that some of the GT series P-cars have.
RSL
503
Can get a little snarky by the end of the week lol I thought maybe it was whole kit or something, that's ridiculous.
Reactions: fmorelli
1,929
664
P/N: 22116793240
Pretty sure it just that the ones with the logo grounded off out of stock so stuck actually buying bmw brand they look identical to the 034 ones that i bought and am hoping the bottom doesnt fall off of
3,629
Huh? I didn't understand your post. The above is the part number for the passenger side factory BMW motor mount for the 331is and the Z4 35is. BMW list price is $681 for that mount. I'm trying to understand what is special about that mount? Seems like Porsche pricing ...
titium
48
9
You use to be able to buy the rein ones from FCP, they were alot cheaper.
I believe they are slightly firmer than a stock 335i mount, highly doubt they are worth the current price, standard 335i mounts are good imo.
3,629
Rein is cheap cost wise, but that's the standard 335i mount. I'm wondering what's so special about the 335is mount. I assume it is stiffer, but I can't imagine the $681 price tag for slightly harder durometer rubber on one motor mount?
1,929
664
You used to be able get the rein version of 335is mount stock is 45 335is is 50 lmao that's the difference it's bs people used to use two passenger mounts for no nvh oem durability and slightly more firm
1,929
664
My 034 mounts have been great plus they were cheap. i bought them when i could have had is mount for 200 but i wanted something little stronger and i the guy with stock diff bushings cause i worried about gear whine, meanwhile my sub frame and diff have been out of the car more times then I've changed my oil
vegasboy
33
67
2009 335i
I thought they had worked out the problems with the 034 mounts. I saw a bad thread and figured they couldn’t all be bad or they wouldn’t make them anymore. They looked good and were a good price so I gave them a try. They didn’t even make it 100 miles. This is my passenger mount, driver side was okay when I removed it. ECS refunded my money.
(Reposted as I uploaded wrong photo)
1,929
664
Question that obviously shouldn't happen but while it's bolted in if torqued down to spec would the cup still pre load the mount and essentially not affect function. If that's case it is very possible every mount is failing on install or right away and just no one realizes except extreme diy guys that pull it out again shortly after.
Reactions: fmorelli
