What do ya think? Log Check
Tuppidsay
116
63
Seattle, WA
2008 535i
Fresh off handling my meth issues, loaded up a more aggressive timing map and proceeded to run about 15 pulls. Checked them all out on VD just to compare as i've always done. These are the best 3 VD wise. What do you guys think? Tips, suggestions?
https://datazap.me/u/tuppidsay/back-bef-16-some-duty-bias-adjustments?log=0&data=1-4
dyezak
1,767
1,518
Plano TX
335is
I can spot major issues and I don't see any. But countless times I've thought a log looked great only for some tuning wizard to point out small issues they can see in the log (usually with a update that resolves that issue and the owner commenting on the improvement).
So I'm going to say...nothing major I can see :)
Tuppidsay
116
63
Seattle, WA
2008 535i
I'm the same, I can see the blatant but the Finer stuff is fuzzy at best. Usually I end up pointing at something that everyone says is nothing but better to error on the side of caution right?
R.G.
668
328
Henderson, NV
E92 335, F10 M5
Your HPFP is only at 14! That can't be good!
Terry and his posse really need to have a little widget to convert these numbers in to the actual converted measurement figures if they're unable to do it with the outputs.
Tuppidsay
116
63
Seattle, WA
2008 535i
  • 2018-03-25 12_12_06.csv
  • 2018-03-25 12_26_26.csv
  • 2018-03-25 12_38_44.csv
