Walnut Blast Timelapse Video
ASquared
34
Las Vegas
If you buy the adapter and blasting wand, I've gotten everything else from Harbor Freight. You just need a compressor, shop vac, and abrasive blaster. If you only plan on doing this once or twice, you can get by using HF gravity feeder. I use the pressurized tank, makes it more efficient, but obviously a little more money. Then just takes a couple fittings from home depot to attach the wand to the blaster. If anybody has walnut blasting questions, feel free to hit me up.
rebo0t
E90 335i
Nice! Also perfect time to do charge pipe and aftermarket intake :)
Nov 14, 2016
651
262
North Wilkesboro
Any suggestions on which compressor I should buy? I'll be buying the adapters from Bimmerhelp but, If anyone know where I could get the full setup please PM me or reply here :) I need to do this badly.. I haven't blasted my car in almost 40k miles now :c
Cjdzombie
72
12
2011 335i xDrive M-Sport
I'm guessing the process would be fairly similar on the N55?
ASquared
34
Las Vegas
I need to get this done.
Road trip man! Vegas ain't far lol
I bought a 26 gallon compressor from HF. It's been solid for me man. You can always message me and I'll walk you through the process. Also get a remote starter switch to bump the valves to close. Safer, easier, and faster than manually cranking the motor.
Got any pics of your set up? I need to get the vacuum and wand adapter.
I'll take some pictures today and post them of my setup.
2,198
How long does the job take you from start to finish? Just curious.
Andy
77
27
California
Looks like it took pretty fast for you.
Should definitely offer this as a service for your area maybe.
4,350
I have a 20 gal air compressor... And I am going to install my intake manifold as well as tap the head...Hmm..
ASquared
34
Las Vegas
Yea I have been doing it to help out my local peoples.
Best time to do it man before you install your new manifold. Especially if you are gonna be running PI, you shouldn't have to worry about it again really.
9kred
BMW E60 535i
My N54 is just about ready for this. To do myself or take it to a local BMW guy.. probably take it in as the intervals are not frequent at all. Great info though
rebo0t
E90 335i
Ya, right tools being key. Just make sure you're all prepared before going forth.
