VMR fitment help
TWilly
85
18
Tyler
C764A9F7-6F40-4138-ACF2-5276DD93CAE4.png hey guys not sure if this is the right section but I got new wheels waiting to put on was wondering if you guys would know if I’d need any spacers, ect.
Car: 07 335i sport suspension
Wheels : front 19x8.5 et38
Rear 19x9.5 et45
Anyone have a set up similar?
I’d preferred not to roll the fenders if not needed
Thanks for your feedbackC764A9F7-6F40-4138-ACF2-5276DD93CAE4.png6850D7CB-9D14-412C-85CF-5A80DB03B777.jpeg
ASquared
34
Las Vegas
Definitely would work, but it’s a very conservative setup. You’re probably gonna want spacers to flush out a little bit. That setup is gonna sit too much inwards honestly. It’s more 135i fitment if anything.
ASquared
34
Las Vegas
thanks for the reply @ASquared, any suggestions on how large of spacers ill need?
In all honesty, I’m running 18x9.5 +28 on the rear of my E90 LCI and still have a little bit of room if I wanted a more aggressive roll. So basically you could run like a 20mm spacer in the rear if you wanted to on pre lci but I would have just rather gotten better spec’d wheels vs using a 20mm spacer. But to answer your question, probably 12mm up front, 20mm rear.
