VIDEO: Single Turbo BMW 135i takes on 1/2 Mile! (vs. Z06, Hellcat, Supra + more)
suspenceful
10 Second Club
Aug 1, 2017
559
592
75
2015 M3, 2008 135i, 2009 335i
Finally got around to compiling this video together from NoFlyZone... let me know what you think! It was too hot for me to feel comfortable about running high boost 6 hours away from home.
Doc Race 6266 Single Turbo 135i
  • Day 1 = 22psi
  • Day 2 = 24-26psi
  • Full modification list below
Follow me on Instagram: https://instagram.com/jakespence
2008 BMW 135i Modification List:
SINGLE TURBO KIT
Doc Race Single Turbo Kit w/ 6266 ball-bearing turbo:
https://docrace.com/collections/turbo-kits/products/bmw-335i-n54-n55-single-turbo-kit
*Save $100 on your kit by using discount code N54JAKE during checkout!*
TUNING
JB4 Tuner: https://amzn.to/2HcCuKD
JB4 Wireless Connect Kit: https://amzn.to/2Hehg2X
Wedge Flash: https://www.facebook.com/WedgePerformance-1253879854659791/
MHD Flashing Cable: https://amzn.to/2qGKbl2
OTG USB Adapter: https://amzn.to/2qKvc9R
PERFORMANCE UPGRADES
VRSF 7.5" Race Intercooler: http://www.vr-speed.com/vrsf-7-5-st...-kit-07-12-135i-335i-n54-n55-e82-e90-e92.html
VRSF Charge Pipe & TiAL BOV: http://www.vr-speed.com/vrsf-chargepipe-upgrade-07-13-bmw-135i-335i-n54-n55.html
Precision Raceworks Ignition Kit: http://www.precisionraceworks.com/index.php?route=product/product&product_id=82
Precision Raceworks Stage 3+ LPFP: http://www.precisionraceworks.com/index.php?route=product/product&product_id=71
Black Market Parts Port Injection Kit: http://www.bm-parts.com/index.php?route=product/product&product_id=188
JB4 Port Injection Controller: http://www.burgertuning.com/N54_secondary_fuel_line_adapter_fuel_Injectors_BMW.html
Oil Catch Can: https://amzn.to/2Hd1p0L
BMS Cowl Filters: https://bit.ly/2l4082g
Upgraded PCV: https://bit.ly/2JC3og0
NGK 5992 Spark Plugs @ 0.022": https://amzn.to/2JWIf0A
3.5 Bar TMAP Sensor Kit: http://www.burgertuning.com/N54_JB4_upgrades.html
TRANSMISSION
SPEC Stage 3+ Clutch: https://bit.ly/2JsSehU
Single-Mass Flywheel: https://bit.ly/2JtLtfN
Race Transmission Mounts: https://bit.ly/2sOXEJH
BMW Performance Short Shift Kit: https://bit.ly/2LGwP15
Teflon Shifter Bushings: https://bit.ly/2JMN5QS
Clutch Pedal Stop: https://bit.ly/2JBEYDu
Clutch Delay Valve Delete
JB4 No-lift-shift/2-step Relay: http://www.burgertuning.com/N54_JB4_upgrades.html
Redline D4 ATF Transmission Fluid: https://amzn.to/2JWbssH
Redline 75W90 Rear Differential Fluid: https://amzn.to/2J6pPt7
WHEELS/SUSPENSION/BRAKES
Front: APEX ARC-8 Wheels (Anthracite): https://bit.ly/2LJxkrx
Rear: Style 68 w/ Mickey Thompson ET Street R (275/40/17)
Eibach Pro-Kit springs: https://bit.ly/2HFyfqm
Stud Conversion Kit: https://amzn.to/2HexoO1
StopTech Drilled & Slotted Rotors w/ Brake Pads: https://amzn.to/2qKFWVA
Awesome! Those prolonged runs sure are much harder on the car. How do you argue with the sound of the Z06 tho. Those were some good pulls, I love it!
Nice not bad for a manual and conditions but those shift bogs are killing me
They will be smashing gears soon. Might even make me a bit jealous of the manual at that point. But, its DCT land for me. Speaking on this, do manuals have a tendency to break the diff pinion also? Or is this just a DCT thing?
blisstik
151
64
E92 MOTIV750 (Sold)
@suspenceful - fellow 6MT here, how's the BMW Performance shifter + teflon shifter bushings? Is 2nd gear still notchy?
suspenceful
10 Second Club
Aug 1, 2017
559
592
75
The Z06 definitely sounds mean. I wish my exhaust tone came thru in videos better. In person, it's intoxicating... people always tell me how amazing it sounds. Then I watch a video and it sounds like a bee buzzing around in a can, lol. Oh well.
Same - waiting on @jyamona's fix to go public so I can stop getting gapped.
Not sure about this...
I'm starting to wonder if I have an OEM shifter. I bought the car and the PO mentioned it had a BMW Performance shifter, but it doesn't feel like it anymore. 1-2 shift is painful sometimes. I just bought an RTD shifter, gonna see how that feels in comparison!
Reactions: R.G.
berns
175
266
'09 135i
Painful shifts. Get an AKG shifter, or CAE if you want to ball out, some solid bushings in the trans and on the motor, fix your shift bog and shift at 7k.
Before that, though, you can try Red Line D4 ATF in the trans. Should fix up your 1-2 shift and everything in between. It fixed my grind on my E90 and I run it in my 135 track car. Recommended by BimmerWorld President James Clay. It works.
suspenceful
10 Second Club
Aug 1, 2017
559
592
75
I already have Redline D4 ATF in the trans. It's probably do for a flush/fill though, as much as I reef on this transmission.
This showed up at my door yesterday. Got a shift-bog flash from Wedge to test out. I've had the clutch wire unplugged for Terry's JB4 "fix", so I didn't think NLS would work. But I tested it last night and it works decently. Hoping all of these things combined will finally get rid of the bog. I'll report back.
berns
175
266
'09 135i
If the D4 wasn’t doing it for you, the next step is Lightweight Shockproof.
The RTD shifter is a nice piece. You have to upgrade motor and trans mounts to close to solid to use it effectively since it’s chassis mounted. Any slop in there will only make your shifting problems worse. Good luck.
suspenceful
10 Second Club
Aug 1, 2017
559
592
75
I put brand new OEM motor mounts in less than 3k miles ago, along with some red poly trans mounts. Hoping for the best.
suspenceful
10 Second Club
Aug 1, 2017
559
592
75
OEM motor mounts move a fuck ton, new or not. It's your car and your choice, but not a good move to run chassis mounted shifters like that.
When you're ready to change, I recommend this setup.
https://www.akgmotorsport.com/product-category/3-series/e9x-2006-2013/motor-and-trans-mounts-e9x/
https://www.akgmotorsport.com/produ...pgrade-set-e30-e36-e46-e82-e90-e92-e93-z3-z4/
I'll see how it feels and go from there. Thanks for the link and input, I'll save it for the future.
suspenceful
10 Second Club
Aug 1, 2017
559
592
75
I got my RTD shifter second-hand from someone who never installed it. Just put it in this weekend and it's incredible. The 2-3 shift is nuts, all you have to do is push straight up.
Trans still grinds from 1-2, so I'm going to try to new fluid this weekend.
What HP was the car putting down on each day?
With the DA, the first day was probably 550whp, second day was probably 600whp.
Reactions: DS3IAM
blisstik
151
64
E92 MOTIV750 (Sold)
Are you able to close the ashtray to hide the spring area?
DCook
274
135
08 BMW e92
Other than chassis mounted vs the stock arm, is it just crisper shifts? If poly everything doesnt help, how would the rtd? I did upgraded poly everything, and misc parts and get 2nd lockout so unsure how it would help at 7krpm. Thats just even more deflection not being trans mounted?
