Upgrading the Exhaust of the N54 Z4
Armando1969
95
54
I wanted to upgrade the Exhaust on my z4 3.5i because of two reasons:
1 As Preparation for a performance upgrade.
2 Some more sound without it being obnoxious.
So what did we do.
Take out the center section of the Exhaust and inserted a Fox X-pipe. This way you get a true X-pipe and get ride of the restriction in the piping to the right backbox. And while we had the Exhaust of the car we installed some stainless/Carbon endpipes.
Armando1969
95
54
The parts before we put them on the car.
Armando1969
95
54
This is the standard exhaust with a blow-up of the restriction that we got rid of
Armando1969
95
54
The work in progress
Armando1969
95
54
The end result.☺
I think it looks nice and it still sounds very civilised, you only hear a difference when you go full throttle.
In two weeks the next stage: Downpipes with racecats and silicone inlets.
Gr Armando
Armando1969
95
54
Is there a reason you want cats in your downpipes?
Exhaust looks sweet!, thanks.😊
Yes, need it to stay legal for our Dutch yearly inspection, going back and forth between cat and downpipes every year is too cumbersome for me. Plus my end target is around 450 horsepower at the engine and I can make that easily with cats.
2,194
Do they sniff your exhaust during the yearly inspection?
Reactions: Armando1969
Dumaurier7
561
231
Hi, what diameter pipe is that? 2.5' ? looks GREAT by the way, I am planning on doing something similar, but I'll be replacing the mufflers too.
Armando1969
95
54
60mm, the same as the connection on the standard mufflers, in inch that is 2,35inch.
Armando1969
95
54
Wonder why the OE pipe is squashed…the new pipe isn’t….clearance OK?
I think it's for sound emissions regulations, this way most of the Exhaust gasses go through the left (bigger) muffler. And yes the clearance is okay, we fitted everything on the car and checked 3 times before we welded everything together.😊
Dumaurier7
561
231
What system is that? Never heard of, can you post a link? I’d like to be able to consider all my options before I pull the trigger. I already bought a pair of DAW flow max + turbos and a PFS POD, VRSF 7.5” race IC, charge pipes etc! wanna make sure those turbos are comfortable!
Armando1969
95
54
My X-pipe is part of the fox system, you can ad the mufflers, picture is below. But then you lose the flap-system that is in the standard mufflers to quiete the Exhaust sound down.
  • silencieux-arriere-duplex-inox-1x100mm-type-25-pour-bmw-z4-type-e89-s-drive-35i.jpg
